[mapserver-users] Re: Question about projection
jjwang
jaja0506 at gmail.com
Wed Aug 24 02:17:40 EDT 2011
Thanks for your reply, Jukka.
The WMS works fine. I can get the map through WMS.
The problem is I need to project the map so that it can match an existing
map which I don't know what exactly the projection systems it's using.
I tries many projection systems. The result seems are all the same.
My map is a little bit higher than the base layer one.
So I'm assuming that the projection doesn't work at all.
JJ
View this message in context: http://osgeo-org.1803224.n2.nabble.com/Question-about-projection-tp6714933p6719004.html
Sent from the Mapserver - User mailing list archive at Nabble.com.
