[mapserver-users] wrong tileindex path make mapserver 6 crash
Jeff McKenna
jmckenna at gatewaygeomatics.com
Tue Aug 30 17:12:19 EDT 2011
I know last week on the Windows benchmarking server for FOSS4G I made
some mistakes with tileindex paths for rasters, with MapServer 6.1-dev
and shp2img, and there was no crash (I used the -all-debug switch to get
the error messages from MapServer). Maybe this is a platform-specific
issue? not sure.
-jeff
Jeff McKenna
MapServer Consulting and Training Services
http://www.gatewaygeomatics.com/
On 11-08-30 5:11 PM, Daniel Morissette wrote:
> Hi Oliver,
> No, a crash is not normal, so we should try to fix it. I made a few
> tests and was unable to reproduce the issue, can you reproduce it with
> the CGI or with shp2img (i.e. without FastCGI)?
> If you could package a small testcase to reproduce the issue with the
> CGI or with shp2img (with mapfile, exact request to trigger the issue,
> etc.) and create a ticket then we'll try to have a look.
> Daniel
> On 11-08-30 06:40 AM, Oliver Christen wrote:
>> hello
>> Im just wondering if it was normal for mapserver 6 to crash instead of
>> returning an error message if a tileindex path was incorrect for a
>> raster layer ?
>> Im using 6.0.0-1
>> I have a raster layer using a tileindex (ortho/ortho.*):
>> LAYER
>> NAME 'ortho'
>> TYPE RASTER
>> STATUS ON
>> TILEINDEX "ortho/ortho"
>> TILEITEM "LOCATION"
>> END
>> at first the TILEINDEX was wrong set to "ortho", so effectively pointing
>> to the folder instead of the files, which is of course wrong, but I
>> would have expected an error message, not a crash.
>> all I have in my error log is:
>> mod_fcgid: error reading data, FastCGI server closed connection
>> Premature end of script headers: mapserv
>> I tried to turn on the debug with:
>> CONFIG "MS_ERRORFILE" "/tmp/ms_error.txt"
>> DEBUG 5
>> CONFIG "CPL_DEBUG" "ON"
>> but ms_error.txt is empty
>> is there any way to be able to obtain some error message which may help
>> knowing where the error is?
>> would this problem be fixed in 6.0.1?
>> thanks in advance
>> best regards
>> Oliver
