[mapserver-users] PHP Mapscript: generateSLD
Daniel Degasperi
daniel.degasperi at r3-gis.com
Tue Feb 8 03:16:49 EST 2011
Ok, ticket created at: http://trac.osgeo.org/mapserver/ticket/3668
Daniel
Am 07/02/2011 18:25, schrieb Lime, Steve D (DNR):
> Documentation mod suggestions can be filed as tickets at http://trac.osgeo.org/mapserver. Just assign it to the "MapServer Documentation" component and we'll handle it like any other defect...
> Steve
> -----Original Message-----
> From: mapserver-users-bounces at lists.osgeo.org [mailto:mapserver-users-bounces at lists.osgeo.org] On Behalf Of Jean-François Gigand
> Sent: Monday, February 07, 2011 11:23 AM
> To: Daniel Degasperi
> Cc: mapserver-users at lists.osgeo.org
> Subject: Re: [mapserver-users] PHP Mapscript: generateSLD
> You're welcome.
> I think this precision would be useful in the documentation. Am not in
> the MapServer team however, and don't know the process for suggesting
> modifications in the doc.
> It seems logical that msMapObj.generateSLD() only includes enabled
> layers, but it's not that clear that it's the same for explicit calls
> to msLayerObj.generateSLD().
> It might also be considered as a program issue... Don't know.
> Jeff
> 2011/2/7 Daniel Degasperi<daniel.degasperi at r3-gis.com>
>> Hi Jeff,
>> thank you very much, now it works.
>> Should this information be included in the documentation?
>> Daniel
>> Am 07/02/2011 17:14, schrieb Jean-François Gigand:
>> Hi,
>> Maybe the layer has to be enabled (STATUS property) to appear in the SLD?
>> If you want to keep it disabled in your mapFile, you can enable it
>> programmatically just before calling generateSLD() by setting "status"
>> to MS_ON.
>> Jeff
>> 2011/2/7 Daniel Degasperi<daniel.degasperi at r3-gis.com>:
>> Hi,
>> I've used the function generateSLD from the layerObj class to create a sld
>> snippet, but the output was a empty sld file:
>> <StyledLayerDescriptor version="1.0.0" xmlns="http://www.opengis.net/sld"
>> xmlns:gml="http://www.opengis.net/gml"
>> xmlns:ogc="http://www.opengis.net/ogc"
>> xmlns:xlink="http://www.w3.org/1999/xlink"
>> xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
>> xsi:schemaLocation="http://www.opengis.net/sld
>> http://schemas.opengis.net/sld/1.0.0/StyledLayerDescriptor.xsd">
>> </StyledLayerDescriptor>
>> I'm using following mapfile with mapserver 5.6.5:
>> MAP
>> NAME "test.map"
>> SIZE 256 256
>> RESOLUTION 72
>> OUTPUTFORMAT
>> NAME "aggpng24"
>> DRIVER "AGG/PNG"
>> MIMETYPE "image/png"
>> IMAGEMODE RGB
>> EXTENSION "png"
>> FORMATOPTION "INTERLACE=OFF"
>> TRANSPARENT ON
>> END
>> WEB
>> METADATA
>> "ows_onlineresource"
>> "http://dev/public/services/ows.php?map=test.map"
>> "ows_title" "test"
>> "ows_abstract" ""
>> "wms_feature_info_mime_type" "text/html"
>> "ows_service_onlineresource" ""
>> "wms_srs" "EPSG:32632 EPSG:4326 EPSG:900913"
>> END
>> IMAGEPATH "/tmp/ms_tmp/"
>> IMAGEURL "/tmp/"
>> END
>> LAYER
>> GROUP "test"
>> NAME "test"
>> TYPE LINE
>> STATUS OFF
>> METADATA
>> "ows_title" "test"
>> "ows_extent" "482003.57067363 5006503.5706736 537996.42932637
>> 5062496.4293264"
>> "ows_srs" "EPSG:32632"
>> "gml_geometries" "the_geom"
>> END
>> PROJECTION
>> "+proj=utm +zone=32 +ellps=WGS84 +datum=WGS84 +units=m +no_defs "
>> END
>> EXTENT 482003.57067363 5006503.5706736 537996.42932637 5062496.4293264
>> CONNECTIONTYPE POSTGIS
>> CONNECTION "user=test password=test dbname=test host=localhost
>> port=5432"
>> DATA "the_geom FROM test USING UNIQUE gid USING SRID 32632"
>> PROCESSING "CLOSE_CONNECTION=DEFER"
>> SIZEUNITS pixels
>> CLASS
>> NAME "l103106"
>> EXPRESSION ('[code]' eq 'L103106')
>> STYLE
>> COLOR 76 230 0
>> SYMBOL "CIRCLE"
>> SIZE 3
>> MINSIZE 3
>> MAXSIZE 3
>> WIDTH 3
>> MINWIDTH 3
>> END
>> END
>> CLASS
>> NAME "l103107"
>> EXPRESSION ('[code]' eq 'L103107')
>> STYLE
>> COLOR 56 168 1
>> SYMBOL "CIRCLE"
>> SIZE 2
>> MINSIZE 2
>> MAXSIZE 2
>> WIDTH 2
>> MINWIDTH 2
>> END
>> END
>> END
>> ###### SYMBOLS #######
>> SYMBOL
>> NAME "CIRCLE"
>> TYPE ELLIPSE
>> FILLED TRUE
>> POINTS
>> 1 1
>> END
>> END
>> END #MAP
>> Can somebody help me?
>> Best regards,
>> Daniel
>> mapserver-users mailing list
>> http://lists.osgeo.org/mailman/listinfo/mapserver-users
>> Daniel Degasperi
>> R3 GIS Srl - GmbH
>> Via Johann Kravogl-Str. 2
>> I-39012 Meran/Merano (BZ)
>> web: www.r3-gis.com
>> Email: daniel.degasperi at r3-gis.com
>> Tel. : +39 0473 494949
>> Fax : +39 0473 069902
>> ATTENZIONE! Le informazioni contenute nella presente e-mail e nei documenti eventualmente allegati sono confidenziali. La loro diffusione, distribuzione e/o riproduzione da parte di terzi, senza autorizzazione del mittente è vietata e può violare il D. Lgs. 196/2003. In caso di ricezione per errore, Vogliate immediatamente informare il mittente del messaggio e distruggere la e-mail.
>> ACHTUNG! Die in dieser Nachricht oder in den beigelegten Dokumenten beinhalteten Informationen sind streng vertraulich. Ihre Verbreitung und/oder ihre Wiedergabe durch Dritte ist ohne Erlaubnis des Absenders verboten und verstößt gegen das Legislativdekret 196/2003. Sollten Sie diese Mitteilung irrtümlicherweise erhalten haben, bitten wir Sie uns umgehend zu informieren und anschließend die Mitteilung zu vernichten.
>> WARNING! This e-mail may contain confidential and/or privileged information. If you are not the intended recipient (or have received this e-mail in error) please notify the sender immediately and destroy this e-mail. Any unauthorised copying, disclousure or distribution of the material in this e-mail is strictly forbidden and could be against the law (D. Lgs. 196/2003)
*Daniel Degasperi*
*R3 GIS* Srl - GmbH
web: www.r3-gis.com <http://www.r3-gis.com/>
Email: daniel.degasperi at r3-gis.com <mailto:daniel.degasperi at r3-gis.com>
*ATTENZIONE!* Le informazioni contenute nella presente e-mail e nei
*ACHTUNG!* Die in dieser Nachricht oder in den beigelegten Dokumenten
*WARNING!* This e-mail may contain confidential and/or privileged
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20110208/f9463983/attachment-0001.html
