[mapserver-users] Re: GetFeatureInfo request in UTF8-environment
Tom van der Putte
tom at vdputte.nl
Tue Feb 8 12:12:50 EST 2011
I had a similar issue, and the solution I used works but is labour intensive. I'm working mobile right now so I can't send you the link, but the solution is on the Esri forum somewhere. It concerns setting a registry key to a certain value. After this, restart ArcGIS (assuming you have this) add the shapefile, and then export it by rightclicking it in the table of contents->
export data. Save it as a different file, and the attribute data will be in UTF8.
I'll see if I have the link somewhere tonight.
Cheers,
Tom
mapserver-users-request at lists.osgeo.orgschreef:
>Send mapserver-users mailing list submissions to
> mapserver-users at lists.osgeo.org
>To subscribe or unsubscribe via the World Wide Web, visit
>or, via email, send a message with subject or body 'help' to
>You can reach the person managing the list at
> mapserver-users-owner at lists.osgeo.org
>When replying, please edit your Subject line so it is more specific
>than "Re: Contents of mapserver-users digest..."
>Today's Topics:
> 1. size of legend icon for pixmap-type classes (NASUNO Isao)
> 2. GetfeatureInfo-Request in an UTF-8 environment with shapfile
> in cp-1252 (Siegel Andreas)
> 3. Re: GetfeatureInfo-Request in an UTF-8 environment with
> shapfile in cp-1252 (Jeff McKenna)
> 4. RE: size of legend icon for pixmap-type classes
> (Lime, Steve D (DNR))
>Message: 1
>Date: Tue, 08 Feb 2011 17:42:23 +0900
>From: NASUNO Isao <isao.nasuno at ctc-g.co.jp>
>Subject: [mapserver-users] size of legend icon for pixmap-type classes
>To: mapserver-users at lists.osgeo.org
>Message-ID: <4D5101EF.9000802 at ctc-g.co.jp>
>Content-Type: text/plain; charset=ISO-2022-JP
>Hello all,
>I'm trying to make mapfile which includes polygon layer
>with pixmap-type symbol classes.
>The symbols are defined like ...
>SYMBOL
> NAME "symbol1"
> TYPE pixmap
> image /somewhere/symbol1.gif
> transparent 1
>END
>The polygon layer with pixmap is drawn perfectly by map mode,
>however in legend mode (mode=legend), the icons drawn like line layer.
>How do I say... it seems that mapserver draws icon for line ( /\/ )
>like ArcMap's line layer using "brush" of the gif image.
>I defined the layer certainly as "type polygon".
> layer
> name "jimon"
> connectiontype postgis
> connection "user=db password=xxxxxxx dbname=DB host=localhost port=5432"
> data "the_geom from polygon"
> status on
> type polygon
> classitem "id"
> projection
> "init=epsg:4326"
> end
> class
> name "pattern1 "
> expression "1"
> style
> symbol "symbol1"
> end
> end
> end
>What I want is normal rectangle-shaped icons filled up with the gif.
>Could anyone help me ?
>Thanks,
>Isao NASUNO
>Message: 2
>Date: Tue, 8 Feb 2011 15:37:35 +0100
>From: "Siegel Andreas" <Andreas.Siegel at vorarlberg.at>
>Subject: [mapserver-users] GetfeatureInfo-Request in an UTF-8
> environment with shapfile in cp-1252
>To: <mapserver-users at lists.osgeo.org>
>Message-ID:
> <5FBE485F93722E4589047FAB5195B63C051B09B8 at AVLRBRCL08A.net.vlr.gv.at>
>Content-Type: text/plain; charset="iso-8859-1"
>Hi.
>Our mapserver-eniromnent entirely works in utf-8 (mapfiles, webserver, postgres, ..) with one exception, that is, all of our shapefiles.
>The shapfiles are created/updated in an Windows-environment by several, external contributors.
>Hence they are encoded in Wiindows-ANSI (cp: 1252).
>If i do an GetFeatureInfo-Request on the attibutes of the shapefiles all special characters ("umlauts") are garbled.
>This is no wonder since the content of the shapefile-attributes must be recoded to utf-8 prior to insertion in the template.html.
>How can this be acomplished? I could not find anything useful in the documentation or with google.
>Mag Andreas Siegel
>Landesvermessungsamt Feldkirch
>Johannitergasse 6, A-6800 Feldkirch
>Tel: +43(0) 5522 / 75482 - 60227
>Fax: +43(0) 5522 / 75482 - 6
>E-Mail: andreas.siegel at vorarlberg.at <mailto:andreas.andreas.sandreas.siegel at vorarlberg.at>
>http://www.vorarlberg.at/lva
>Rechtsverbindlichen Schriftverkehr
>(zB Antr�ge, Rechtsmittel) richten Sie an:
>E-Mail: landesvermessungsamt at vorarlberg.at
>Fax: +43(0)5522/75482-6
>-------------- next part --------------
>An HTML attachment was scrubbed...
>URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20110208/b94ad66d/attachment-0001.html
>Message: 3
>Date: Tue, 08 Feb 2011 10:48:49 -0400
>From: Jeff McKenna <jmckenna at gatewaygeomatics.com>
>Subject: Re: [mapserver-users] GetfeatureInfo-Request in an UTF-8
>Message-ID: <4D5157D1.3050508 at gatewaygeomatics.com>
>Content-Type: text/plain; charset=UTF-8; format=flowed
>Hello,
>A quick thought that I had when I read your issue, is that I recently
>came across a similar issue when I was working with Japanese data. In
>that case for MapServer to display query results in my template
>properly, I had to change the character set in the HTML template file,
>otherwise the characters would be garbled:
><!-- MapServer Template -->
><html>
><head>
><meta http-equiv="Content-Type" content="text/html; charset=Shift_JIS">
><title>������</title>
>I'm not sure if that is related to your exact issue, but those are my
>quick thoughts.
>-jeff
>Jeff McKenna
>MapServer Consulting and Training Services
>http://www.gatewaygeomatics.com/
>On 11-02-08 10:37 AM, Siegel Andreas wrote:
>> Hi.
>> *Mag Andreas Siegel*
>Message: 4
>Date: Tue, 8 Feb 2011 10:23:59 -0600
>From: "Lime, Steve D (DNR)" <Steve.Lime at state.mn.us>
>Subject: RE: [mapserver-users] size of legend icon for pixmap-type
> classes
>To: NASUNO Isao <isao.nasuno at ctc-g.co.jp>,
> "mapserver-users at lists.osgeo.org" <mapserver-users at lists.osgeo.org>
>Message-ID:
> <A7F7B3043D3BF0438F1206BAA3C9933C082682318C at MNMAIL05.ead.state.mn.us>
>Content-Type: text/plain; charset="us-ascii"
>What version are we talkin'?
>Steve
>-----Original Message-----
>From: mapserver-users-bounces at lists.osgeo.org [mailto:mapserver-users-bounces at lists.osgeo.org] On Behalf Of NASUNO Isao
>Sent: Tuesday, February 08, 2011 2:42 AM
>Hello all,
>SYMBOL
> NAME "symbol1"
> TYPE pixmap
> transparent 1
>END
> layer
> name "jimon"
> status on
> type polygon
> classitem "id"
> projection
> "init=epsg:4326"
> end
> class
> name "pattern1 "
> expression "1"
> style
> symbol "symbol1"
> end
> end
> end
>Thanks,
>Isao NASUNO
>_______________________________________________
>End of mapserver-users Digest, Vol 37, Issue 13
