[mapserver-users] Dynamic WMS Service - Projections problem?
joanne.mcgraw at sympatico.ca
Tue Feb 8 17:23:32 EST 2011
Beautiful, yes. After a bit of fudging and adjusting (because I don't actually have access to the actual server I'm really trying to use), I managed to get it "not" working on my localhost as it was "not" working on that server. On localhost I was able to put the DEBUG in the map file and see the results. It told me that it couldn't resolve the host (Host not found).
There is an extra '/' in the path being put in the WMC. Instead of http://<domain>/... in the OnlineResource, it is getting http:///<domain>/... during the process. Now I just have to figure out why that's happening but I'm sure it won't be difficult.
Thank you for reminding me of the DEBUG.
Cheers,
jtm
> From: jean-francois at gigand.fr
> Date: Tue, 8 Feb 2011 22:32:59 +0100
> Subject: Re: [mapserver-users] Dynamic WMS Service - Projections problem?
> To: joanne.mcgraw at sympatico.ca
> CC: mapserver-users at lists.osgeo.org
> Hi,
> Have you checked the MapServer logs?
> To enable it, set the env variable MS_ERRORFILE to the log file path
> and MS_DEBUGLEVEL to "5".
> It will detail interesting details about how your layers are built.
> Jeff
> 2011/2/8 myOpenLayersUName <joanne.mcgraw at sympatico.ca>:
> > First, the background...
> > I have a WMS Service that has an "empty" point layer in it. I use it to
> > display labels at dynamically generated coordinates by passing x,y within
> > the request. For example:
> > http://<domain>/ogc/mapserv?map=/path/fenceLabelWms_en.map&map.layer[fencelabel]=FEATURE
> > POINTS -105.5620661354989 51.14394472618872 END TEXT "Fence 1"
> > END&map.layer[fencelabel].class[0]=COLOR 255 0 0
> > END&map.layer[fencelabel].class[0]=LABEL COLOR 255 0 0 SIZE 10 POSITION UR
> > END&LAYERS=fencelabel&mode=map
> > The entire map file is as follows:
> > MAP
> > NAME "fenceLabelWms_en"
> > FONTSET "../../../mapserv/etc/fonts.txt"
> > SYMBOLSET "../../../mapserv/etc/symbols.sym"
> > SIZE 400 300
> > IMAGETYPE PNG
> > IMAGECOLOR 255 255 255
> > RESOLUTION 96
> > EXTENT -141.5 41.5 -51.5 83.5 # all of Canada
> > UNITS METERS
> > PROJECTION
> > "init=epsg:4269" # lat/long
> > END
> > WEB
> > METADATA
> > "wms_srs" "EPSG:42304"
> > END
> > END
> > OUTPUTFORMAT
> > NAME png
> > DRIVER 'GD/PNG'
> > MIMETYPE 'image/png'
> > IMAGEMODE PC256 #RGB
> > FORMATOPTION "INTERLACE=OFF"
> > EXTENSION 'png'
> > TRANSPARENT ON
> > END
> > LAYER
> > NAME "fencelabel"
> > STATUS ON
> > TYPE point
> > CLASS
> > SIZE 0
> > COLOR 0 0 0
> > LABEL
> > TYPE truetype
> > FONT verdana
> > ANTIALIAS false
> > END
> > END
> > END
> > END
> > A number of applications use this WMS and each has its own projection but,
> > as in the request above, all pass the x,y as lat/long (EPSG:4269). The MAP
> > METADATA's "wms_srs" lists the supported projections (for the purposes of
> > this example, I'm simplifying by only including EPSG:42304).
> > So, this allows me to provide the point coordinates in lat/long, but display
> > them using the projection from the application itself. For example:
> > POINTS -105.5620661354989 51.14394472618872 END TEXT 'Fence 1'
> > END&LAYERS=fencelabel&FORMAT=image/png&SRS=EPSG:42304&TRANSPARENT=true&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&EXCEPTIONS=application/vnd.ogc.se_inimage&BBOX=-2903297.000,-789911.0000,3431059.000,3959683.000&WIDTH=1219&HEIGHT=601
> > Knowing this, I can define this "dynamic" layer within a WMC <Layer> tag and
> > load it into an OpenLayers Map (whose projection is set to EPSG:42304 and
> > extents encompass all of Canada). The WMC definition for the above layer is
> > as follows (we use a batch script to set the path to the MapServer
> > executable and MAP file, "fenceLabelWms_en"):
> > <Layer queryable="0" hidden="0">
> > <Server service="OGC:WMS" version="1.1.1">
> > <OnlineResource xlink:type="simple"
> > xlink:href="http://<domain>/ogc/fenceLabelWms_en?map.layer[fencelabel]=FEATURE%20POINTS%20-105.5620661354989%2051.14394472618872%20END%20TEXT%20'Fence%201'%20END&map.layer[fencelabel].class[0]=COLOR%20255%20105%200%20END&map.layer[fencelabel].class[0]=LABEL%20COLOR%20255%20105%200%20SIZE%2010%20POSITION%20LR%20END"/>
> > </Server>
> > <Name>fencelabel</Name>
> > <Title>Fence 1</Title>
> > <SRS>EPSG:42304</SRS>
> > <FormatList>
> > <Format current="1">image/png</Format>
> > </FormatList>
> > <Extension>
> > <ol:maxExtent minx="-2903297.000" miny="-789911.0000"
> > maxx="3431059.000" maxy="3959683.000"/>
> > <ol:transparent>true</ol:transparent>
> > <ol:numZoomLevels>5</ol:numZoomLevels>
> > <ol:units>m</ol:units>
> > <ol:isBaseLayer>false</ol:isBaseLayer>
> > <ol:displayInLayerSwitcher>false</ol:displayInLayerSwitcher>
> > <ol:singleTile>true</ol:singleTile>
> > </Extension>
> > </Layer>
> > Okay, everything works fine up to this point. The fence label WMS is
> > displayed in the OpenLayers Map correctly in relation to the other layers it
> > contains, all of which have projections of EPSG:42304.
> > Now, the problem ...
> > I’d like to print the image displayed to the user. To do this, I have
> > another "empty" MAP file that I use to print the WMC; the same WMC I loaded
> > into OpenLayers. The entire contents of this MAP file are:
> > MAP
> > NAME "wmsContextServer"
> > SIZE 400 300
> > STATUS ON
> > IMAGETYPE PNG
> > EXTENT -2338951 -800000 3008692 3900000
> > UNITS METERS
> > CONFIG "CGI_CONTEXT_URL" "1"
> > PROJECTION
> > "init=epsg:42304"
> > END
> > RESOLUTION 96
> > REFERENCE
> > # Parameter settings NOT to change
> > STATUS ON
> > COLOR -1 -1 -1
> > OUTLINECOLOR 255 0 0
> > # Parameter settings that will change if you replace the default
> > 'refmap.png'
> > IMAGE "../htdocs/images/refmap.png"
> > SIZE 100 74
> > EXTENT -2.2e+006 -712631 3.0728e+006 3.84e+006
> > END # REFERENCE
> > SCALEBAR
> > STATUS EMBED
> > INTERVALS 1
> > POSITION LL
> > TRANSPARENT true
> > UNITS kilometers
> > STYLE 1
> > SIZE 100 7
> > LABEL
> > SIZE small
> > END
> > END
> > WEB
> > INCLUDE "../../../mapserv/conf/imagepath.inc.map"
> > METADATA
> > # Used for App Page Title
> > "wms_title" "WMC Context Client"
> > "wms_connectiontimeout" "60"
> > END
> > END
> > OUTPUTFORMAT
> > NAME png
> > DRIVER 'GD/PNG'
> > IMAGEMODE RGB
> > EXTENSION 'png'
> > #TRANSPARENT ON
> > END
> > OUTPUTFORMAT
> > NAME gif
> > DRIVER 'GD/GIF'
> > MIMETYPE 'image/gif'
> > IMAGEMODE RGB
> > EXTENSION 'gif'
> > END
> > END
> > Unfortunately, the "dynamic" WMS layer doesn't appear in the output image. I
> > can use the following URL to get an image of all the other layers in the WMC
> > successfully, but the fence label is not shown and there is no error
> > message:
> > http://<domain>/ogc/mapserv?map=/path/wmsContextServer.map&mode=map&context=http://<domain>/contexts/WMCwFenceLabels.xml&layers=all
> > I'm guessing MapServer is getting a blank image when it's assembling the
> > layers for the output image and I'm further guessing that this is the result
> > of the projections somehow getting out of whack somewhere along the line.
> > I'm thinking that the point is being evaluated as not actually existing
> > within the extents of the output image being generated, perhaps? But, I
> > can't guess why this would be the case. There is no question that it does
> > fall within the extents (as witnessed by loading the same WMC in
> > OpenLayers).
> > As it is now, I am completely stuck as to what the problem might be. Can
> > anyone suggest anything that might help me narrow down exactly what the
> > problem is or a direction I can investigate further?
> > View this message in context: http://osgeo-org.1803224.n2.nabble.com/Dynamic-WMS-Service-Projections-problem-tp6004893p6004893.html
> > Sent from the Mapserver - User mailing list archive at Nabble.com.
> > mapserver-users mailing list
> > http://lists.osgeo.org/mailman/listinfo/mapserver-users
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20110208/2f679478/attachment.html
