[mapserver-users] changing dynamically LABEL BACKGROUNDCOLOR
tommaso
tommasodb at googlemail.com
Wed Feb 9 06:54:59 EST 2011
thanks Steven this was the right solution.
greetings,
Tommaso
On Tue, 2011-02-01 at 09:07 -0600, Lime, Steve D (DNR) wrote:
> Actually I just ran a test against 5.6 and found I could change a labels background color via URL. Syntax is:
> map.layer[some_layer].class[0]=LABEL+BACKGROUNDCOLOR+255+0+0+END
> Steve
> ________________________________________
> From: tommaso [tommasodb at googlemail.com]
> Sent: Monday, January 31, 2011 11:36 AM
> To: Lime, Steve D (DNR)
> Cc: mapserver-users at lists.osgeo.org
> Subject: RE: [mapserver-users] changing dynamically LABEL BACKGROUNDCOLOR
> Hallo Steve,
> I can try to hack the source (or rather I'll ask a workmate). More details were welcome, thanks.
> Regards,
> Tommaso
> On Mon, 2011-01-31 at 10:08 -0600, Lime, Steve D (DNR) wrote:
> Been on a short holiday, where did this get left? If you can hack the source it's a very simple change (I think) to maplexer.l to allow the updates you need. I can provide more direction if necessary. - Steve
> From: mapserver-users-bounces at lists.osgeo.org<mailto:mapserver-users-bounces at lists.osgeo.org> [mapserver-users-bounces at lists.osgeo.org<mailto:mapserver-users-bounces at lists.osgeo.org>] On Behalf Of tommaso [tommasodb at googlemail.com<mailto:tommasodb at googlemail.com>]
> Sent: Thursday, January 27, 2011 11:55 AM
> To: mapserver-users at lists.osgeo.org<mailto:mapserver-users at lists.osgeo.org>
> Subject: Re: [mapserver-users] changing dynamically LABEL BACKGROUNDCOLOR
> On Thu, 2011-01-27 at 16:47 +0100, Julien Cigar wrote:
> use SLD ?
> Thanks, this were a solution but I should radically change my project. I will try it if there is not other ways.
> Other ideas?
> Tommaso
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20110209/51e81f8e/attachment.html
