[mapserver-users] Buffer features?
Bistrais, Bob
Bob.Bistrais at maine.gov
Tue Feb 15 12:26:01 EST 2011
Thanks everyone! I'm trying to keep up!
From: Lime, Steve D (DNR) [mailto:Steve.Lime at state.mn.us]
Sent: Tuesday, February 15, 2011 12:22 PM
To: Tamas Szekeres
Cc: mapserver-users
Subject: RE: [mapserver-users] Buffer features?
Not quite, I'm thinking of a single layer setup:
LAYER
DATA myfile.shp # or whatever connection information is necessary
TYPE POLYGON
STATUS DEFAULT
NAME 'buffered_shapes'
GEOMTRANSFORM (buffer([shape], 500)) # buffer each shape by 500 map
units
# classes and styles follow
TEMPLATE 'void'
END
The GEOMTRANSFORM would be applied as shapes are pulled from a data
source so you would draw or, potentially, query the transformed shapes.
The difference between a layer-level GEOMTRANSFORM and a style-level one
is the coordinates they operate on. Layer-level work would be done on a
raw feature in map coordinates and style-level works on pixels. We do
layer-level stuff already, conceptually, in the form of projections and
clipping. The GEOMTRANSFORM just provides a way of extending that
work...
Note this type of GEOMTRANSFORM expression is working for buffers in
STYLEs in trunk (but using pixels for the moment).
Steve
From: Tamas Szekeres [mailto:szekerest at gmail.com]
Sent: Tuesday, February 15, 2011 11:12 AM
To: Lime, Steve D (DNR)
Cc: mapserver-users
Subject: Re: [mapserver-users] Buffer features?
Steve,
Did you mean to achieve something like?:
LAYER
CONNECTIONTYPE TRANSFORM
CONNECTION sourcelayer # reference to another layer
NAME transformlayer
PROCESSING "TRANSFORM=(buffer([shape]))"
TEMPLATE query.html
END
LAYER
CONNECTIONTYPE SHAPE
DATA myfile.shp
NAME sourcelayer
END
Which is simple and easy to implement.
Best regards,
Tamas
2011/2/15 Lime, Steve D (DNR) <Steve.Lime at state.mn.us>
I'd approach RFC 22, especially the transform piece, differently now
with the parser changes implemented in 6.0. We now have (with GEOS
enabled) an expression syntax available to support things like
buffering, convex hull, differences, etc... or combinations thereof. I'd
implement layer-level GEOMTRANSFORMs in that case using these
expressions.
On the query result side of things I'd consider adding a layer template
as a layer option. This would kinda work like the approach outlined for
Bob. You'd define a presentation template layer (no DATA value) and run
the query results through it instead of the regular layer (for certain
querymap types, e.g. highlight).
Steve
[mailto:mapserver-users-bounces at lists.osgeo.org] On Behalf Of Tamas
Szekeres
Sent: Tuesday, February 15, 2011 3:06 AM
To: Bistrais, Bob
Cc: mapserver-users
In accordance with the problem mentioned, I recall a resonable
enhancement as described in RFC22a
<http://www.mapserver.org/development/rfc/ms-rfc-22a.html> which would
provide an option to configure all the stuff in the mapfile (not
requiring MapScript) and would make it easier to customize the query
maps as well.
With this enhancement 2 new layer data providers could be implemented,
like:
1. CONNECTIONTYPE=QUERYRESULT would provide to represent the result sets
of one layer in a new layer.
2. CONNECTIONTYPE=TRANSFORM would provide simple geometry
transformations on a source layer and then provide the modified features
as a new layer.
By chaining these layers together in a map configuration we could get
such results
<http://trac.osgeo.org/mapserver/attachment/ticket/2128/sample4.png> as
included in the RFC document.
I consider this kind of enhancement could be implemented within the
scope of 1-2 days of work (comparable with a fully elaborated MapScript
solution providing the same)
Best regards,
Tamas
2011/2/14 Bistrais, Bob <Bob.Bistrais at maine.gov>
This question may have come up before, but I haven't found it in the
archives. I would like to take a selected feature and buffer it to a
specified distance. I know it's possible to do a queryByPoint with a
buffer distance, but I need to create an actual buffer shape to display
on the map. Has anyone done something like this before? Does MapServer
have this capability?
mapserver-users mailing list
mapserver-users at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/mapserver-users
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20110215/71d57083/attachment.html
