[mapserver-users] mapscript php with agg rendering?
Jean-François Gigand
jean-francois at gigand.fr
Tue Feb 15 12:54:21 EST 2011
Great!
Thanks for the ticket. I will also prefer to manage output formats
programmatically.
I will follow that.
Jeff
2011/2/15 Michael Schulz <mandschulz at googlemail.com>:
> Jean-Francois,
> you saved my day :-) That got it working...
> I definitely think there is something wrong when trying to create an
> outputformat with php/mapscript from scratch. I'll try to narrow this
> down a bit and maybe open the mentioned ticket again.
> Thanks, Michael
> 2011/2/15 Jean-François Gigand <jean-francois at gigand.fr>:
>> I had the same problem, with PHP MapScript.
>> In my case, I needed to let MapServer handle the WMS request
>> (msMap->owsDispatch() or CGI with generated MapFile), so I would have
>> no control over the output format selection (which depends of the WMS
>> request).
>> It seemed that MapScript does not give control over the list of output formats.
>> Eventually, as a workaround, I define my output formats as a map
>> string and create the map object with ms_newMapObjFromString() rather
>> than ms_newMapObj().
>> Here is my code :
>> $formats = array
>> ('aggpng24' => array('driver' => 'AGG/PNG',
>> 'imagemode' => 'RGB',
>> 'mimetype' => 'image/png',
>> 'extension' => 'png'),
>> 'aggjpeg' => array('driver' => 'AGG/JPEG',
>> 'mimetype' => 'image/jpeg',
>> 'extension' => 'jpg'),
>> 'gdtiff' => array('driver' => 'GDAL/GTiff',
>> 'mimetype' => 'image/tiff',
>> 'extension' => 'tif'),
>> 'gdgif' => array('driver' => 'GD/GIF',
>> 'imagemode' => 'PC256',
>> 'mimetype' => 'image/gif',
>> 'extension' => 'gif'),
>> $mapStrContent = array('MAP');
>> foreach ($formats as $name => $format) {
>> $mapStrContent[] = 'OUTPUTFORMAT';
>> $mapStrContent[] = 'NAME '.$name;
>> foreach ($format as $prop => $val) {
>> $mapStrContent[] = strtoupper($prop).' "'.$val.'"';
>> $mapStrContent[] = 'END';
>> $msMap = ms_newMapObjFromString(implode("\n", $mapStrContent));
>> To me, this is a bug, as I thought that anything definable in a map
>> file should be definable thought MapScript as well.
>> If there is a full MapScript solution for this need, I'm interested too.
>> Jeff Gigand
>> 2011/2/15 Gregor at HostGIS <gregor at hostgis.com>:
>>> Hey there. I had some issues with the imagetype settings using PHP
>>> MapScript, but we do use PNG24. For what it's worth, here's the outputformat
>>> section of our PHP:
>>> $map->imagecolor->setRGB(255,255,255);
>>> $map->outputformat->set('name','gif');
>>> $map->outputformat->set('mimetype','image/png; mode=24bit');
>>> $map->outputformat->set('driver','AGG/PNG');
>>> $map->outputformat->set('imagemode',MS_IMAGEMODE_RGBA);
>>> $map->outputformat->set('transparent',MS_OFF);
>>> $map->outputformat->set('extension','png');
>>> $map->outputformat->setOption('INTERLACE','OFF');
>>> //$map->outputformat->setOption('QUANTIZE_FORCE','ON');
>>> //$map->outputformat->setOption('QUANTIZE_COLORS',256);
>>> For reasons which now elude my memory (this was written some 3 years ago) we
>>> had to use 'gif' as the output format, then simply reconfigure what 'gif'
>>> means. This may have been a bug specific to our own version of MapServer
>>> back in the day, but if it helps, I'm glad.
>>> HostGIS, Open Source solutions for the global GIS community
>>> Greg Allensworth - SysAdmin, Programmer, GIS Person, Security
>>> Network+ Server+ A+ Security+ Linux+
>>> PHP PostgreSQL MySQL DHTML/JavaScript/AJAX
>>> "No one cares if you can back up — only if you can recover."
>>> mapserver-users mailing list
>>> mapserver-users at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/mapserver-users
> Michael Schulz
> Christoph-Mang-Str. 5
> D-79100 Freiburg
