[mapserver-users] trouble migrating from ms4w to IIS5.1 - ecw blank
christian
cstock at skm.com.au
Wed Feb 16 00:32:13 EST 2011
I've setup MapServer via MS4W which works fine. I'm trying to migrate
MapServer from Apache to IIS 5.1 which is working mostly, however, I can't
get a map file including an ECW to work, all I get is a blank page.
1) I'm running Apache on port 85 (and IIS on default port 80), ie:
http://localhost:85/cgi-bin/mapserv.exe?map=c:/ms4w/spot_vic.map&layer=SPOT_Vic&mode=map
This works fine.
2) I copied all files in Apache/cgi-bin to Inetpub/Server and created a
virtual dir with executable permissions. I tried all examples from 1-1 to
1-9 and they all run just fine, ie
http://localhost/Scripts/mapserv.exe?map=/ms4w/apps/tutorial/htdocs/example1-5.map&layer=states&layer=states_line&layer=states_label&layer=modis&mode=map
works just fine
If I try
http://localhost/Scripts/mapserv.exe?map=c:/ms4w/spot_vic.map&layer=SPOT_Vic&mode=map
I get a blank map. This has me stumped as it's using exactly the same map
file as I'm using on Apache and both solutions are set up on the same
computer (IIS port 80, Apache port 85)
Obviously I need to set up something else in IIS, but I don't know what as
I'm not getting an error message and the example map files from the tutorial
work just fine.
Here's the map file, but it should be fine as it works using Apache:
# Start of map file
MAP
CONFIG "PROJ_LIB" "C:/ms4w/proj/nad/"
NAME "SPOT_Victoria"
STATUS ON
SIZE 948 598
IMAGETYPE PNG24
EXTENT 140.9999817 -39.4999999 150.4999952 -33.4999853
UNITS METERS
SHAPEPATH "D:/Documents and Settings/cstock/My Documents/- Web
Data/SPOTMaps VIC"
IMAGECOLOR 255 255 255
WEB
METADATA
"wms_title" "SPOT Victoria"
"wms_onlineresource" "http://localhost/Scripts/mapserv.exe?"
"wms_srs" "EPSG:4326"
END
END
PROJECTION
"init=epsg:4326"
END
# Start of layer definitions
LAYER
NAME "SPOT_Vic"
TYPE RASTER
#PROCESSING "BANDS=1,2,3"
STATUS ON
DATA "AUK_25x.ecw"
METADATA
"wms_title" "SPOT_Vic"
END
PROJECTION
"init=epsg:4326"
END
END # Layer
END # Map File
View this message in context: http://osgeo-org.1803224.n2.nabble.com/trouble-migrating-from-ms4w-to-IIS5-1-ecw-blank-image-tp6030606p6030606.html
Sent from the Mapserver - User mailing list archive at Nabble.com.
