[mapserver-users] problem of legend icon for pixmap-filling
type polygon layer
Lime, Steve D (DNR)
Steve.Lime at state.mn.us
Fri Feb 18 10:55:21 EST 2011
I can confirm the issue. Not sure what's going on but something's broken in the legend generation. I'll try and sum
things up and file a ticket against 5.6. We won't patch back to 5.0 for something like this.
As a workaround you might consider setting a KEYIMAGE in your class definition. Make it the same size as your legend
"chips" (usually something like 25x15) and that image will be used instead of creating one dynamically. I tried that
here and it seems to work. You should be able to clip a section of a MapServer-created map out for this purpose.
Steve
-----Original Message-----
From: mapserver-users-bounces at lists.osgeo.org [mailto:mapserver-users-bounces at lists.osgeo.org] On Behalf Of Isao NASUNO
Sent: Thursday, February 17, 2011 6:29 PM
To: mapserver-users at lists.osgeo.org
Subject: Re: [mapserver-users] problem of legend icon for pixmap-filling type polygon layer
Hello Steve,
I am using gd-2.0.33, with MapServer 5.0.2.
Thank you,
Isao
(2011/02/18 6:54), Lime, Steve D (DNR) wrote:
> Which driver are you using (AGG or GD)? I'll run some tests here and report back... Steve
> Sent: Wednesday, February 16, 2011 11:20 PM
> Subject: [mapserver-users] problem of legend icon for pixmap-filling type polygon layer
> Hello all,
> I had send same question 2 weeks ago but I have no response,
> so I try again with more detail of the problem.
> ** situation **
> I'm trying to make pixmap-filled polygon maps and I did it without problem,
> however a problem in getting legend.
> I want legend icons by mapserver cgi with request "mode=legend" like following.
> (base pattern) (what I want)
> oxoxoxoxoxox
> xoxoxoxoxoxo
> oxox oxoxoxoxoxox
> xoxo ------> xoxoxoxoxoxo
> However I get following. It is like a legend icon of line layer.
> oxox oxox
> oxoxox oxoxo
> oxoxoxoxoxoxo
> oxoxo oxoxoxo
> oxoxo oxoxo
> xoxo xoxo
> ** version **
> I'm using MapServer 5.0.2 on CentOS 5.2.
> I also try MapServer 5.6.x (forgot for detail), but the situation is same.
> ** what I did **
> The symbol is defined like ...
> SYMBOL
> NAME "symbol1"
> TYPE pixmap
> image /somewhere/symbol1.gif
> transparent 1
> END
> The layer is as following...
> layer
> name "jimon"
> connectiontype postgis
> connection "user=db password=xxxxxxx dbname=DB host=localhost port=5432"
> data "the_geom from polygon"
> status on
> type polygon
> classitem "id"
> projection
> "init=epsg:4326"
> end
> class
> name "pattern1 "
> expression "1"
> style
> symbol "symbol1"
> end
> end
> end
> Could anyone please help me !?
> Isao
