[mapserver-users] RE: polygon tool
Shorthouse, David
dshorthouse at eol.org
Fri Feb 18 13:12:08 EST 2011
Bob,
This may not be what you have in mind, but you're welcome to take a
peek at: http://bsc-localities.webhop.org/. Please note however that
this is a very interim service under development and the URL will most
certainly change. This was build in pure PHP MapScript and if you
would like the code, drop me a line; I haven't yet deposited it
anywhere.
Cheers,
David P. Shorthouse
On Fri, Feb 18, 2011 at 2:37 AM, Tom van der Putte <tom at vdputte.nl> wrote:
> Hi Bob,
> You could also try using Fusion, it also has a polygon tool in there, but
> again its based on Open Layers. I gues you can make your own, but you'd need
> some sort of framework that converts the drawn polygon to the location,
> projection and units that your basemap is in, for which openLayers is the
> perfect framework I think.
> Tom van der Putte
> From: mapserver-users-bounces at lists.osgeo.org
> [mapserver-users-bounces at lists.osgeo.org] On Behalf Of Bistrais,
> Bob
> Sent: Thursday, February 17, 2011 8:18 AM
> To: mapserver-users
> Subject: [mapserver-users] polygon tool
> I am trying to create a polygon tool with PHP MapScript and JavaScript.
> I
> used to select map features. This kind of thing probably has been done
> before. Can anyone direct me to some code samples?
> mapserver-users at lists.osgeo.org
