[mapserver-users] MySQL Join
Jeff McKenna
jmckenna at gatewaygeomatics.com
Fri Feb 18 14:22:48 EST 2011
Hello Mike,
This news won't help you, but when I was testing and documenting
MapServer joins I ran into the same mapserv crash with MySQL 5.1.49 on
Windows (see the bottom of http://www.mapserver.org/mapfile/join.html);
but at the time I assumed I was doing something wrong with MySQL. Or it
is possible that there is a problem here. Do others have this same
problem? If yes, then we should file a MapServer ticket with a small
test case.
-jeff
Jeff McKenna
MapServer Consulting and Training Services
http://www.gatewaygeomatics.com/
On 11-02-18 2:50 PM, Michael Neimeyer wrote:
> Hello all -
> I am trying to do a Join from a shapefile to a MySQL table but I am
> getting an internal error. I am not interested in any spatial
> reference, I just want to link up the shapefile to the MySQL table to
> reference data for the identify service. One thing I noticed is the
> templates for the JOIN are not being recognized so that might be causing
> an issue. I don't need to use the JOIN templates as I plan on defining
> the columns in the Metadata reference.
> Any idea why the JOIN might not be working for MySQL? Is there a
> certain version of MySQL that is needed for MapServer?
> Thanks for your help!
> Mike
