[mapserver-users] Labels are cut at the borders of the tiles
Niccolo Rigacci
niccolo at rigacci.org
Mon Jan 10 09:00:25 EST 2011
On Mon, Jan 10, 2011 at 01:45:25PM +0100, Rudert, Clemens VGD wrote:
> I have a problem with a annotation. I tried to write some
> numbers at specified points. I use OpenLayers for rendering.
> Now when i try to render the map i get the lables but at the
> border oft the tiles the lables are cut. Below you see the
> layer definition in my map file:
> FORCE true
> PARTIALS false
The setting MAP.LAYER.CLASS.LABEL.FORCE true implies
MAP.LAYER.CLASS.LABEL.PARTIALS is set to true too.
As far I know there is not a real solution to the label problem
when using a tiled map, as with OpenLayers.
Niccolo Rigacci
Firenze - Italy
