[mapserver-users] WARNING: Mandatory metadata '..._GROUP_TITLE'
was missing in this
thomas bonfort
thomas.bonfort at gmail.com
Wed Jan 12 04:32:50 EST 2011
Ralf,
not really related to your problem at hand, but the image you provided
is exhibiting a bug in the mapserv-utils mapfile. You should change it
locally, in two places:
UNITS meters must be UNITS dd
and
the wms_srs metadata key should be capitalized.
as for your original request, have a look at wms_group_title in
http://mapserver.org/ogc/wms_server.html#layer-object-metadata .
best regards,
thomas
On Wed, Jan 12, 2011 at 08:38, Eckert, Ralf
<ralf.eckert at stadt-gummersbach.de> wrote:
> Hi,
> The system was created for this website:
> http://trac.osgeo.org/mapserver/wiki/RenderingOsmData
> UMN MapServer as Server on Linux 5.6.5 is used incl PROJ4, PostgreSQL /
> PostGIS
> As the district map Cologne has been deposited.
> The self-test with the command:
> / path/to/mapserver/shp2img-m-o osm.map osm.png
> led to a usable image, s: http://gis.gummersbach.de/koeln.png
> The map file was installing itself, and OSM
> supplemented with the epsg of me: Currently running the following map file:
> MAP
> OUTPUTFORMAT
> NAME agg
> DRIVER AGG/PNG
> IMAGEMODE RGB
> FORMATOPTION "INTERLACE=false"
> MIMETYPE "image/png"
> END
> FONTSET "fonts.lst"
> IMAGETYPE agg
> MAXSIZE 4000
> SIZE 800 800
> EXTENT 5.8668561 50.3353631 7.7911996 51.2502162
> UNITS meters
> IMAGECOLOR "#B3C6D4"
> WEB
> METADATA
> wms_srs "epsg:900913 epsg:31467 epsg:31493 epsg:4326"
> labelcache_map_edge_buffer "-10"
> wms_title "osm stadt-gummersbach"
> END
> END
> DEBUG 10
> CONFIG "PROJ_LIB" "/home/gkz212/tmp/mapserver-utils"
> CONFIG "MS_ERRORFILE" "stderr"
> PROJECTION
> "init=epsg:4326"
> END
> LAYER
> TYPE POLYGON
> STATUS ON
> GROUP "default"
> NAME "land"
> PROJECTION
> "init=epsg:900913"
> END
> DATA "coastlines/processed_p"
> CLASS
> STYLE
> COLOR "#EDEBE6"
> OUTLINECOLOR "#EDEBE6"
> END
> END
> END
> END
> Do I get the following error message GetCapabilities:
> <Layer>
> <Name>MS</Name>
> <Title>osm stadt-gummersbach</Title>
> <Abstract>MS</Abstract>
> <SRS>epsg:900913</SRS>
> <SRS>epsg:31467</SRS>
> <SRS>epsg:31493</SRS>
> <SRS>epsg:4326</SRS>
> <LatLonBoundingBox minx="5.86686" miny="50.3354" maxx="7.7912"
> maxy="51.2502" />
> <BoundingBox SRS="EPSG:4326"
> minx="5.86686" miny="50.3354" maxx="7.7912" maxy="51.2502"
> <Layer>
> <Name>default</Name>
> <!-- WARNING: Mandatory metadata '..._GROUP_TITLE' was missing in this
> context. -->
> <Title>default</Title>
> <Abstract>default</Abstract>
> <Layer queryable="0" opaque="0" cascaded="0">
> <Name>land</Name>
> <!-- WARNING: Mandatory metadata '..._title' was missing in this context.
> <Title>land</Title>
> <SRS>EPSG:900913</SRS>
> <LatLonBoundingBox minx="-180" miny="-85.0512" maxx="180"
> maxy="83.6693" />
> <BoundingBox SRS="EPSG:900913"
> minx="-2.00375e+07" miny="-2.00377e+07"
> maxx="2.00375e+07" maxy="1.84644e+07" />
> </Layer>
> </Layer>
> </Layer>
> Does anyone have an approach as I get this error fixed?
> The attempt to replace the double quotes with simple, gives the same error.
> Ralf Eckert
> Stadtverwaltung Gummersbach
> FB9 - GIS / Vermessung
> Rathausplatz 1
> 51463 Gummersbach
> Tel: 02261 - 872303
> mapserver-users at lists.osgeo.org
