Fwd: [mapserver-users] Reporting lat/long from projected map units
Milo van der Linden
milo at dogodigi.net
Wed Jan 12 11:03:15 EST 2011
---------- Forwarded message ----------
Date: 2011/1/12
Subject: Re: [mapserver-users] Reporting lat/long from projected map units
To: "Bistrais, Bob" <Bob.Bistrais at maine.gov>
Are you talking bout a web-app? Do you use a client like OpenLayers? What
programming language(s) do you use? Is your datasource a database? Like
postgis?
If you can get UTM coordinates from the mouseclick, the next best option (in
my opinion) would be to use proj4js:
http://proj4js.org/
Simply embed the js-library ad an event for mouse handling and convert:
screen->utm->4326.
2011/1/12 Bistrais, Bob <Bob.Bistrais at maine.gov>
> This should be fairly straightforward, but I was wondering what is the
> easiest and quickest way to convert coordinates on the fly. All my data is
> in UTM coordinates. I want to report coordinates to the screen in
> Lat/Long. Changing the projections on the map files to lat/long (*
> EPSG:4326)* is not an option, as this will cause problems elsewhere. So
> what I want to do is take point coordinates, either from a mouse click or
> from UTM coordinates, project to lat/long, which will be reported in a
> result window. What is the quickest way to do this?
> mapserver-users at lists.osgeo.org
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20110112/b41acbbd/attachment.html
