[mapserver-users] Label text always clipped by tiles
Gregor at HostGIS
gregor at hostgis.com
Wed Jan 26 10:41:15 EST 2011
I came into this conversation a bit late, but...
So you're tiling, and using MS as your backend. Are you using TileCache
or similar in between? If so, TileCache supports "meta-tiling" which may
help your label problems significantly.
Using meta-tiling, TileCache requests a much larger tile (say a 5x5
tile) and slices it up. Thus, MapServer generates fewer tile edges and
truncated/missing labels.
That's aside from the obvious benefits of caching your tiles, if your
layer isn't subject to change often such that caching is appropriate.
HostGIS, Open Source solutions for the global GIS community
Greg Allensworth - SysAdmin, Programmer, GIS Person, Security
Network+ Server+ A+ Security+ Linux+
PHP PostgreSQL MySQL DHTML/JavaScript/AJAX
"No one cares if you can back up — only if you can recover."
