[mapserver-users] Label text always clipped by tiles
Mike Stoddart
stodge at gmail.com
Wed Jan 26 10:43:20 EST 2011
Thanks Gregor,
I was using TileCache, but I switched it off to debug this problem. If
TileCache generates larger tiles, will there still be clipped labels?
Just fewer clipped labels? I don't think this is a workable solution
for me, but if I have the time I'll try it.
Thanks
Mike
On Wed, Jan 26, 2011 at 10:41 AM, Gregor at HostGIS <gregor at hostgis.com> wrote:
> I came into this conversation a bit late, but...
> So you're tiling, and using MS as your backend. Are you using TileCache or
> similar in between? If so, TileCache supports "meta-tiling" which may help
> your label problems significantly.
> Using meta-tiling, TileCache requests a much larger tile (say a 5x5 tile)
> and slices it up. Thus, MapServer generates fewer tile edges and
> truncated/missing labels.
> That's aside from the obvious benefits of caching your tiles, if your layer
> isn't subject to change often such that caching is appropriate.
> HostGIS, Open Source solutions for the global GIS community
> Greg Allensworth - SysAdmin, Programmer, GIS Person, Security
> Network+ Server+ A+ Security+ Linux+
> PHP PostgreSQL MySQL DHTML/JavaScript/AJAX
> "No one cares if you can back up — only if you can recover."
