[mapserver-users] Label text always clipped by tiles
Mike Stoddart
stodge at gmail.com
Wed Jan 26 11:37:43 EST 2011
Sorry, the server is on my laptop and isn't accessible from the
outside world. Yeah I've been burned too with a stale cache so I
delete it everytime I make a change. I also restart Apache to make
sure the new configuration is read.
test.map:
LAYER
NAME "test_text"
CONNECTIONTYPE postgis
CONNECTION "host=localhost port=5432 dbname=dbname user=username
password=password"
DATA "the_geom from gis_geometry using unique id"
FILTER "dataset='test_text' and etype='text'"
STATUS DEFAULT
PROCESSING "LABEL_NO_CLIP=ON"
TYPE POINT
TRANSPARENCY ALPHA
LABELITEM "text"
PROJECTION
"init=epsg:4326"
END
CLASS
NAME "text"
STYLE
COLOR 0 0 0
END
LABEL
TYPE TRUETYPE
FONT "free-vera"
SIZE 10
COLOR 255 0 0
POSITION CC
PARTIALS TRUE
FORCE TRUE
END
END
END
tilecache.cfg:
[test_text]
type=MapServerLayer
layers=test_text
mapfile=/opt/test.map
bbox=-50000, -50000, 50000, 50000
extension=png
srs=epsg:4326
extent_type=loose
resolutions=390.625, 195.3125, 97.65625, 48.828125, 24.4140625,
12.20703125, 6.103515625, 3.0517578125, 1.52587890625, 0.762939453125,
0.3814697265625, 0.19073486328125, 0.095367431640625,
0.0476837158203125, 0.02384185791015625, 0.011920928955078125,
0.0059604644775390625, 0.0029802322387695312, 0.0014901161193847656,
0.00074505805969238281
extent_type=loose
metaTile=true
metaBuffer=20
Thanks
Mike
On Wed, Jan 26, 2011 at 11:30 AM, Gregor at HostGIS <gregor at hostgis.com> wrote:
> On 1/26/2011 8:25 AM, Mike Stoddart wrote:
>> I set metaBuffer to 20 (I have SIZE=10) and there's no difference.
>> metaTile="yes"
>> metaBuffer=20
> Try metaTile=true, without the " marks.
> And of course, erase any existing cached tiles, so you're sure to be
> generating new ones. I hate when I forget that; it's so embarrassing. :)
> Then, the relevant paragraph and maybe a URL of the map?
> HostGIS, Open Source solutions for the global GIS community
> Greg Allensworth - SysAdmin, Programmer, GIS Person, Security
> Network+ Server+ A+ Security+ Linux+
> PHP PostgreSQL MySQL DHTML/JavaScript/AJAX
> "No one cares if you can back up — only if you can recover."
