[mapserver-users] Re: make cannot find -libodbc and -libodbcinst on
compilation
gregcorradini
gregcorradini at gmail.com
Wed Jan 26 22:43:23 EST 2011
Much thnx to Jeff for his reply.
I ran $ ldconfig -v >/tmp/ldconfig.output.txt 2>&1
I found libodbc* in the output to be in exactly the same directories as when
I run $ sudo find / -name libodbc*
So as far as i can tell this means gdal-config is saying my libodbc*
libraries should be one place when they are somewhere else. Makes sense that
mapserver is errors out on make. Not sure how that happened.
I tried editing the Makefile after configuring it to account for these
differences but just got the same error.
I then tried compiling mapserver without GDAL support. When i did that
postgis started throwing me similar errors about libxslt, libpam and
libreadline
Not sure.
View this message in context: http://osgeo-org.1803224.n2.nabble.com/make-cannot-find-libodbc-and-libodbcinst-on-compilation-tp5962776p5965117.html
Sent from the Mapserver - User mailing list archive at Nabble.com.
