[mapserver-users] changing dynamically LABEL BACKGROUNDCOLOR
Jean-François Gigand
jean-francois at gigand.fr
Thu Jan 27 16:55:14 EST 2011
Use one CLASS for each colour used, set them to depend on your
attribute and repeat the LABEL definition for each of them.
If you the number of colours is limited, this would probably be a solution.
Jeff
2011/1/27 tommaso <tommasodb at googlemail.com>:
> On Thu, 2011-01-27 at 16:47 +0100, Julien Cigar wrote:
> use SLD ?
> Thanks, this were a solution but I should radically change my project. I
> will try it if there is not other ways.
> Other ideas?
> Tommaso
> mapserver-users at lists.osgeo.org
