[mapserver-users] Re: GD rendering: polygons vs lines
Stephen Woodbridge
woodbri at swoodbridge.com
Thu Jan 27 20:01:08 EST 2011
Steve,
Thanks for clarifying that.
Sorry for the mistake on that.
I guess I need to go back and reread the RFC on this.
-Steve W
On 1/27/2011 3:01 AM, Lime, Steve D (DNR) wrote:
> To clarify GD is not being removed. It's still alive and kicking.
> It's just more isolated now. That is, AGG doesn't need GD in 6.0 like
> it has in the past. AGG, GD, Cairo all exist as rendering peers. We
> have stripped back the GD functionality to be just 8-bit output
> though. That's what it's good for.
> So, rendering issues with GD are and will be of concern. You might
> try a 6.0 build and see if that helps at all. Much of the rendering
> behavior is much more consistent across renderers thanks to Thomas'
> work.
> Steve
> ________________________________________ From:
> mapserver-users-bounces at lists.osgeo.org
> [mapserver-users-bounces at lists.osgeo.org] On Behalf Of Gregor at
> HostGIS [gregor at hostgis.com] Sent: Wednesday, January 26, 2011 10:31
> PM To: Stephen Woodbridge Cc: mapserver-users at lists.osgeo.org
> Subject: Re: [mapserver-users] Re: GD rendering: polygons vs lines
>> A while back someone, maybe Thomas Bonfort, did some performance
>> tests comparing GD to AGG, and if I recall AGG was only slightly
>> slower and in at least a couple of cases it was faster the GD.
> In our case, GD renders in 1 second and AGG in 3 in these few tests
> cases we're concerned with. We're thus allowing a choice between
> "fast mode" and "good quality mode"
>> Also I should point out that the GD renderer is getting removed So
>> I'm not sure there is much interest in chasing issue
> Well, that's good to know. Thanks for the heads-up. I'll wait and see
> if someone comes up with any ideas before I give up entirely.
> -- HostGIS, Open Source solutions for the global GIS community Greg
> Allensworth - SysAdmin, Programmer, GIS Person, Security Network+
> Server+ A+ Security+ Linux+ PHP PostgreSQL MySQL
> DHTML/JavaScript/AJAX
> "No one cares if you can back up — only if you can recover."
> _______________________________________________ mapserver-users
> mailing list mapserver-users at lists.osgeo.org
