[mapserver-users] python mapscript issue
Jeff McKenna
jmckenna at gatewaygeomatics.com
Sat Jan 29 11:21:19 EST 2011
On 11-01-29 12:10 PM, bs wrote:
> Hi there,
> I'm using an example from Ben Kroplas book: Beginning in GIS on how to use
> Mapscript Python bindings for projecting a map image.
> For some reason, however, when I attempt to create an image (image =
> map.draw()) the method does not return anything. It just hangs...
> see code here: http://codepad.org/jLB7SrFV http://codepad.org/jLB7SrFV
When I cause MapServer to crash I always enable debugging
(http://www.mapserver.org/optimization/debugging.html), usually the
cause will be in the MapServer log file. Then if not I check the Apache
log file for the exact URL causing the problem, and then I run that CGI
query string at the commandline (again that is documented in that link
provided).
Sunny Saturday here on the east coast of Canada :)
-jeff
Jeff McKenna
MapServer Consulting and Training Services
http://www.gatewaygeomatics.com/
