[mapserver-users] Re: python mapscript issue
bs
bogdansuvar at gmail.com
Sat Jan 29 13:02:51 EST 2011
thanks Jeff! from the cloudy Eastern England, tried both and found nothing,
but went on with the debugging in a Python IDE which interestingly enough
does not help in identifying the issue - the IDE still hanging when the
map.draw() is called.
moreover,
the definition of the draw() function is:
def draw(*args): return _mapscript.rectObj_draw(*args)
and even step-by-step debugging of the script did not yield any errors.
View this message in context: http://osgeo-org.1803224.n2.nabble.com/python-mapscript-issue-tp5972926p5973144.html
Sent from the Mapserver - User mailing list archive at Nabble.com.
