[mapserver-users] wms server - raster image quality
Brent Fraser
bfraser at geoanalytic.com
Thu Jul 7 10:28:54 EDT 2011
Mark,
You could try having mapserver render PNG files instead of JPEG. And
since there's a re-projection from zone 13 to 14, perhaps mapserver is
reading a lower resolution level from the mrsid file; adding
PROCESSING "LOAD_FULL_RES_IMAGE=YES"
to the layer def might help (or it might not).
Best Regards,
Brent Fraser
On 7/1/2011 9:26 AM, Mark Volz wrote:
> Hello
> I set up a WMS Server using Mapserver. The quality of the map is
> terrible. If anyone an example of a mapfile to serve imagery via wms
> it would be appreciated.
> Thanks
> MAP
> NAME "MAP"
> EXTENT 699283 4853930 736320 4904147
> PROJECTION
> "init=epsg:26914"
> END #PROJECTION
> OUTPUTFORMAT
> NAME 'gd/jpeg'
> #DRIVER GD/JPEG
> IMAGEMODE RGB
> #IMAGEMODE PC256
> FORMATOPTION "TRANSPARENT=FALSE"
> FORMATOPTION "QUALITY=90"
> DRIVER "AGG/JPEG"
> MIMETYPE "image/jpeg"
> END #outputformat
> MAXSIZE 10000 #limit size of wms
> IMAGETYPE gd/jpeg
> WEB
> IMAGEPATH '/tmp/'
> IMAGEURL '/tmp/'
> METADATA
> 'wms_title' 'MAP'
> 'wms_onlineresource'
> 'http://localhost/cgi-bin/mapserv.exe?MAP=/ms4w/apps/PipestoneMOOSE/maps_pipestone/Raster/LocalRaster/FSA2010/LocalFSA2010.map'
> 'wms_srs' 'EPSG:26914'
> END #metadata
> END #web
> LAYER
> NAME 'FSA'
> TYPE RASTER
> DATA './ortho_1-1_1n_s_mn117_2010_1.sid'
> METADATA
> 'wms_title' 'FSA'
> END #metadata
> STATUS DEFAULT
> PROJECTION
> "proj=utm"
> "zone=14"
> "ellps=GRS80"
> "datum=NAD83"
> "units=m"
> "no_defs"
> END #PROJECTION
> PROCESSING "OVERSAMPLE_RATIO=1"
> END #layer
> END ## end Map
> Mark Volz
> GIS Specialist
> mapserver-users at lists.osgeo.org
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20110707/891f9ccf/attachment.html
