[mapserver-users] msShapefileOpen(): Unable to access file
Brent Fraser
bfraser at geoanalytic.com
Wed Jul 13 09:55:51 EDT 2011
Dave,
Strange, it should work. I'm using mapserver v5.6.3, with a layer def of:
LAYER # LINE
NAME 'LINE'
CONNECTIONTYPE OGR
STATUS on
TILEINDEX "G:\GeoData\1_250k\Alberta\AltaLIS\250k_west.shp"
TYPE LINE
PROJECTION
'proj=tmerc'
'ellps=GRS80'
'lat_0=0.0'
'lon_0=-117.0'
'x_0=500000.0'
'y_0=-5000000'
'k=0.9996'
'units=m'
'nadgrids=@null'
'no_defs'
END
INCLUDE "AltaLIS_250k_render_inc.map"
END
and the content of the "location" attribute reported by ogrinfo is :
LOCATION (String) = G:\GeoData\1_250k\Alberta\AltaLIS\82gpos.dgn
Try adding a PROJECTION object to your LAYER def. And try using a full
path in the TILEINDEX.
Best Regards,
Brent Fraser
On 7/13/2011 5:08 AM, Dave Chetan wrote:
> Hi Brent,
> After changes my Layer tag is
> LAYER
> NAME "DGN"
> CONNECTIONTYPE OGR
> STATUS ON
> TILEINDEX "index_dgn.shp"
> TILEITEM "location"
> TYPE LINE
> UNITS METERS
> CLASS
> NAME "DGN"
> STYLE
> ANGLE 360
> COLOR 240 215 209
> SYMBOL "LineDash"
> WIDTH 1
> END
> END
> END
> and the error message is
> INPUT=SHAPEFILE
> Exception executing MapControl::RefreshMap
> 7/13/2011 4:30:13 PM|msConnPoolRegister(): General error message.
> Missing CONNECTION on layer DGN.;msConnPoolRegister(): General error
> message. Missing CONNECTION on layer DGN.;msConnPoolRegister():
> General error message. Missing CONNECTION on layer
> DGN.;msConnPoolRegister(): General error message. Missing CONNECTION
> on layer DGN.;msConnPoolRegister(): General error message. Missing
> CONNECTION on layer DGN.;msConnPoolRegister(): General error message.
> 7/13/2011 4:30:13 PM| at OSGeo.MapServer.mapObj.draw()
> at MapCreator.Controls.MapControl.RefreshMap()
> Regards,
> Dave C.
> On 7/12/11, Brent Fraser<bfraser at geoanalytic.com> wrote:
>> Dave,
>> I've had good success rendering DGN files referenced in a TILEINDEX
>> (http://lists.osgeo.org/pipermail/mapserver-users/2010-December/067444.html).
>> Try adding ".shp" to the end of your TILEINDEX:
>> TILEINDEX "index_dg.shp"
>> as OGR handles the files differently than Mapserver's native shapefile
>> mechanism.
>> Best Regards,
>> Brent Fraser
>> On 7/12/2011 6:25 AM, Dave Chetan wrote:
>>> Dear Jukka,
>>> Yes, I am able to publish single DGN.
>>> But when I go for tiled dgn, I have error.
>>> Regards,
>>> Dave C.
>>> On 7/12/11, Rahkonen Jukka<Jukka.Rahkonen at mmmtike.fi> wrote:
>>>> Hi,
>>>> I have never played with DGN files with Mapserver. I would blindly follow
>>>> the documents and try first with just one DGN file as in
>>>> http://mapserver.org/input/vector/dgn.html
>>>> and forward next to ogrtileindex as in
>>>> http://mapserver.org/input/vector/ogr.html
>>>> Perhaps there is something important in the syntax of TILEINDEX given in
>>>> the
>>>> following example.
>>>> LAYER
>>>> NAME "ogr_points"
>>>> TYPE POINT
>>>> CONNECTIONTYPE OGR
>>>> TILEINDEX "PIP_ogr_tiles.shp,0"
>>>> -Jukka Rahkonen-
>>>> ________________________________________
>>>> Lähettäjä: Dave Chetan [csdave4u at gmail.com]
>>>> Lähetetty: 12. heinäkuuta 2011 14:58
>>>> Vastaanottaja: Rahkonen Jukka
>>>> Kopio: mapserver-users at lists.osgeo.org
>>>> Aihe: Re: [mapserver-users] msShapefileOpen(): Unable to access file
>>>> Hi Rahkonen,
>>>> Thanks for the prompt reply..!!
>>>> If I add
>>>> CONNECTIONTYPE OGR
>>>> in the Layer Tag, then the error is
>>>> 7/12/2011 4:29:20 PM|msDrawMap(): Image handling error. Failed to draw
>>>> layer named 'DGN'.;msOGRFileOpen(): OGR error. Open failed for OGR
>>>> connection in layer `DGN'. File not found or unsupported format.
>>>> 7/12/2011 4:29:20 PM| at OSGeo.MapServer.mapObj.draw()
>>>> Regards,
>>>> Dave C.
>>>>> Hi,
>>>>> I guess that Mapserver is seaching for shapefiles as default. Read the
>>>>> document http://mapserver.org/input/vector/ogr.html and have a try with
>>>>> CONNECTIONTYPE=OGR.
>>>>> -Jukka Rahkonen
>>>>> Dave Chetan wrote:
>>>>> Hi,
>>>>> I am publishing DGN data using tile option. I am getting error
>>>>> "msShapefileOpen(): Unable to access file".
>>>>> Following are the details of Input data, steps executed and error log.
>>>>> Please, if anyone can help in resolving the issue.
>>>>> Source files are DGN
>>>>> D:\Tile\DGN\Final\1.dgn
>>>>> D:\Tile\DGN\Final\3.dgn
>>>>> D:\Tile\DGN\Final\5.dgn
>>>>> D:\Tile\DGN\Final\7.dgn
>>>>> D:\Tile\DGN\Final\9.dgn
>>>>> Step1)-
>>>>> Creation of Index tile
>>>>> ogrtindex.exe d:\Tile\DGN\Final\index_dgn.shp d:\Tile\DGN\Final\*.dgn
>>>>> Ogrtindex created "index_dgn.shp" index file
>>>>> Step2)-
>>>>> Map file
>>>>> EXTENT 699218.75297987 2251967.57943806 755021.241547886
>>>>> 2291053.54827586
>>>>> SHAPEPATH "D:\Tile\DGN\Final"
>>>>> LAYER
>>>>> NAME "DGN"
>>>>> STATUS ON
>>>>> TILEINDEX "index_dgn"
>>>>> TILEITEM "location"
>>>>> TYPE LINE
>>>>> UNITS METERS
>>>>> CLASS
>>>>> NAME "DGN"
>>>>> STYLE
>>>>> ANGLE 360
>>>>> COLOR 240 215 209
>>>>> SYMBOL "LineDash"
>>>>> WIDTH 1
>>>>> END
>>>>> END
>>>>> END
>>>>> Error
>>>>> 7/12/2011 4:21:33 PM|msDrawMap(): Image handling error. Failed to draw
>>>>> layer named 'DGN'.;msTiledSHPOpenFile(): Shapefile error. Unable to
>>>>> open a single tile to use as a template in layer
>>>>> DGN.;msShapefileOpen(): Unable to access file.
>>>>> (d:\Tile\DGN\Final\9.dgn,0);msShapefileOpen(): Unable to access file.
>>>>> (d:\Tile\DGN\Final\7.dgn,0);msShapefileOpen(): Unable to access file.
>>>>> (d:\Tile\DGN\Final\5.dgn,0);msShapefileOpen(): Unable to access file.
>>>>> (d:\Tile\DGN\Final\3.dgn,0);msShapefileOpen(): Unable to access file.
>>>>> (d:\Tile\DGN\Final\1.dgn,0);msShapefileOpen(): Unable to access file.
>>>>> 7/12/2011 4:21:33 PM| at OSGeo.MapServer.mapObj.draw()
>>>>> In the Layer Tag if I add following line
>>>>> CONNECTIONTYPE OGR
>>>>> the error is
>>>>> _______________________________________________
>>>>> mapserver-users mailing list
>>>>> http://lists.osgeo.org/mailman/listinfo/mapserver-users
