[mapserver-users] msShapefileOpen(): Unable to access file
Rahkonen Jukka
Jukka.Rahkonen at mmmtike.fi
Wed Jul 13 10:08:14 EDT 2011
One remark: the "missing connection" error was a fault alarm (CONNECTION is not needed with TILEINDEX). We got those lines into log file at least with Mapserver 5.2 series but it has been corrected later. Version 6.0 does not produce those. I do not remember what was the situation with 5.4.x and 5.6.x.
Add DEBUG 5 into your layer, let's hope it will generate something useful into into Mapserver log.
-Jukka Rahkonen-
________________________________________
Lähettäjä: mapserver-users-bounces at lists.osgeo.org [mapserver-users-bounces at lists.osgeo.org] käyttäjän Brent Fraser [bfraser at geoanalytic.com] puolesta
Lähetetty: 13. heinäkuuta 2011 16:55
Vastaanottaja: Dave Chetan
Kopio: mapserver-users at lists.osgeo.org
Aihe: Re: [mapserver-users] msShapefileOpen(): Unable to access file
Dave,
Strange, it should work. I'm using mapserver v5.6.3, with a layer def of:
LAYER # LINE
NAME 'LINE'
CONNECTIONTYPE OGR
STATUS on
TILEINDEX "G:\GeoData\1_250k\Alberta\AltaLIS\250k_west.shp"
TYPE LINE
PROJECTION
'proj=tmerc'
'ellps=GRS80'
'lat_0=0.0'
'lon_0=-117.0'
'x_0=500000.0'
'y_0=-5000000'
'k=0.9996'
'units=m'
'nadgrids=@null'
'no_defs'
END
INCLUDE "AltaLIS_250k_render_inc.map"
END
and the content of the "location" attribute reported by ogrinfo is :
LOCATION (String) = G:\GeoData\1_250k\Alberta\AltaLIS\82gpos.dgn
Try adding a PROJECTION object to your LAYER def. And try using a full
path in the TILEINDEX.
Best Regards,
Brent Fraser
On 7/13/2011 5:08 AM, Dave Chetan wrote:
> Hi Brent,
> After changes my Layer tag is
> LAYER
> NAME "DGN"
> CONNECTIONTYPE OGR
> STATUS ON
> TILEINDEX "index_dgn.shp"
> TILEITEM "location"
> TYPE LINE
> UNITS METERS
> CLASS
> NAME "DGN"
> STYLE
> ANGLE 360
> COLOR 240 215 209
> SYMBOL "LineDash"
> WIDTH 1
> END
> END
> END
> and the error message is
> INPUT=SHAPEFILE
> Exception executing MapControl::RefreshMap
> 7/13/2011 4:30:13 PM|msConnPoolRegister(): General error message.
> Missing CONNECTION on layer DGN.;msConnPoolRegister(): General error
> message. Missing CONNECTION on layer DGN.;msConnPoolRegister():
> General error message. Missing CONNECTION on layer
> DGN.;msConnPoolRegister(): General error message. Missing CONNECTION
> on layer DGN.;msConnPoolRegister(): General error message. Missing
> CONNECTION on layer DGN.;msConnPoolRegister(): General error message.
> 7/13/2011 4:30:13 PM| at OSGeo.MapServer.mapObj.draw()
> at MapCreator.Controls.MapControl.RefreshMap()
> Regards,
> Dave C.
> On 7/12/11, Brent Fraser<bfraser at geoanalytic.com> wrote:
>> Dave,
>> I've had good success rendering DGN files referenced in a TILEINDEX
>> (http://lists.osgeo.org/pipermail/mapserver-users/2010-December/067444.html).
>> Try adding ".shp" to the end of your TILEINDEX:
>> TILEINDEX "index_dg.shp"
>> as OGR handles the files differently than Mapserver's native shapefile
>> mechanism.
>> Best Regards,
>> Brent Fraser
>> On 7/12/2011 6:25 AM, Dave Chetan wrote:
>>> Dear Jukka,
>>> Yes, I am able to publish single DGN.
>>> But when I go for tiled dgn, I have error.
>>> Regards,
>>> Dave C.
>>> On 7/12/11, Rahkonen Jukka<Jukka.Rahkonen at mmmtike.fi> wrote:
>>>> Hi,
>>>> I have never played with DGN files with Mapserver. I would blindly follow
>>>> the documents and try first with just one DGN file as in
>>>> http://mapserver.org/input/vector/dgn.html
>>>> and forward next to ogrtileindex as in
>>>> http://mapserver.org/input/vector/ogr.html
>>>> Perhaps there is something important in the syntax of TILEINDEX given in
>>>> the
>>>> following example.
>>>> LAYER
>>>> NAME "ogr_points"
>>>> TYPE POINT
>>>> CONNECTIONTYPE OGR
>>>> TILEINDEX "PIP_ogr_tiles.shp,0"
>>>> -Jukka Rahkonen-
>>>> Lähettäjä: Dave Chetan [csdave4u at gmail.com]
>>>> Lähetetty: 12. heinäkuuta 2011 14:58
>>>> Vastaanottaja: Rahkonen Jukka
>>>> Hi Rahkonen,
>>>> Thanks for the prompt reply..!!
>>>> If I add
>>>> CONNECTIONTYPE OGR
>>>> in the Layer Tag, then the error is
>>>> 7/12/2011 4:29:20 PM|msDrawMap(): Image handling error. Failed to draw
>>>> layer named 'DGN'.;msOGRFileOpen(): OGR error. Open failed for OGR
>>>> connection in layer `DGN'. File not found or unsupported format.
>>>> 7/12/2011 4:29:20 PM| at OSGeo.MapServer.mapObj.draw()
>>>> Regards,
>>>> Dave C.
>>>>> Hi,
>>>>> I guess that Mapserver is seaching for shapefiles as default. Read the
>>>>> document http://mapserver.org/input/vector/ogr.html and have a try with
>>>>> CONNECTIONTYPE=OGR.
>>>>> -Jukka Rahkonen
>>>>> Dave Chetan wrote:
>>>>> Hi,
>>>>> I am publishing DGN data using tile option. I am getting error
>>>>> "msShapefileOpen(): Unable to access file".
>>>>> Following are the details of Input data, steps executed and error log.
>>>>> Please, if anyone can help in resolving the issue.
>>>>> Source files are DGN
>>>>> D:\Tile\DGN\Final\1.dgn
>>>>> D:\Tile\DGN\Final\3.dgn
>>>>> D:\Tile\DGN\Final\5.dgn
>>>>> D:\Tile\DGN\Final\7.dgn
>>>>> D:\Tile\DGN\Final\9.dgn
>>>>> Step1)-
>>>>> Creation of Index tile
>>>>> ogrtindex.exe d:\Tile\DGN\Final\index_dgn.shp d:\Tile\DGN\Final\*.dgn
>>>>> Ogrtindex created "index_dgn.shp" index file
>>>>> Step2)-
>>>>> Map file
>>>>> EXTENT 699218.75297987 2251967.57943806 755021.241547886
>>>>> 2291053.54827586
>>>>> SHAPEPATH "D:\Tile\DGN\Final"
>>>>> LAYER
>>>>> NAME "DGN"
>>>>> STATUS ON
>>>>> TILEINDEX "index_dgn"
>>>>> TILEITEM "location"
>>>>> TYPE LINE
>>>>> UNITS METERS
>>>>> CLASS
>>>>> NAME "DGN"
>>>>> STYLE
>>>>> ANGLE 360
>>>>> COLOR 240 215 209
>>>>> SYMBOL "LineDash"
>>>>> WIDTH 1
>>>>> END
>>>>> END
>>>>> END
>>>>> Error
>>>>> 7/12/2011 4:21:33 PM|msDrawMap(): Image handling error. Failed to draw
>>>>> layer named 'DGN'.;msTiledSHPOpenFile(): Shapefile error. Unable to
>>>>> open a single tile to use as a template in layer
>>>>> DGN.;msShapefileOpen(): Unable to access file.
>>>>> (d:\Tile\DGN\Final\9.dgn,0);msShapefileOpen(): Unable to access file.
>>>>> (d:\Tile\DGN\Final\7.dgn,0);msShapefileOpen(): Unable to access file.
>>>>> (d:\Tile\DGN\Final\5.dgn,0);msShapefileOpen(): Unable to access file.
>>>>> (d:\Tile\DGN\Final\3.dgn,0);msShapefileOpen(): Unable to access file.
>>>>> (d:\Tile\DGN\Final\1.dgn,0);msShapefileOpen(): Unable to access file.
>>>>> 7/12/2011 4:21:33 PM| at OSGeo.MapServer.mapObj.draw()
>>>>> In the Layer Tag if I add following line
>>>>> CONNECTIONTYPE OGR
>>>>> the error is
>>>>> _______________________________________________
>>>>> mapserver-users mailing list
>>>>> http://lists.osgeo.org/mailman/listinfo/mapserver-users
