[mapserver-users] Re: Can't WFS getFeature w/MapServer 6.0.1
myOpenLayersUName
joanne.mcgraw at SYMPATICO.CA
Thu Jul 21 14:36:11 EDT 2011
Absolutely, we'd be happy to test a patch.
I have some additional info (which you probably already know at this point
but I'll pass it along just in case). I started looking into the WMS
GetFeatureInfo request failure that Michelle was reporting in her post and
found that ultimately it was the exact same problem.
In that case, mapquery.c's msQueryByPoint makes an msLayerClose call on a
layer that is not open (line 1535). Again, it ultimately gets down to the
msSDELayerFreeItemInfo function where the layer->layerinfo is null, so
sde->basedefs causes a segmentation fault. So, somewhere, there just needs
to be a check that stops the attempt to free memory if the memory is not
allocated at that time.
Anyway, I'll send you an email directly to give you my coordinates and we'll
arrange to try the patch.
Cheers,
jtm
View this message in context: http://osgeo-org.1803224.n2.nabble.com/Can-t-WFS-getFeature-w-MapServer-6-0-1-tp6600286p6608020.html
Sent from the Mapserver - User mailing list archive at Nabble.com.
