[mapserver-users] Question: loadWeb(): Unknown identifier.
Parsing error near (ms_tmp):(line 36)
Steve Lime
sdlime at gmail.com
Mon Jul 25 00:30:04 EDT 2011
In MapServer 6.0, the GD driver can only produce 8-bit output so your output
format is invalid. Try commenting it out and see what happens. I believe you
can leave "IMAGETYPE png" in place and you'll get AGG-based, 8-bit output.
Should look much nicer.
Steve
On Sun, Jul 24, 2011 at 11:14 PM, Mihaela Caluian <mihaela.caluian at gmail.com
> wrote:
> Hello everybody,
> I am very new to MapServer and I have a lots of problem that I cannot find
> answer.
> Currently I am having trouble to figure out what is wrong with my .map
> files. I am getting this error when I try to click the button to load the
> map file:
> loadWeb(): Unknown identifier. Parsing error near (ms_tmp):(line 49)
> msOutputFormatValidate(): General error message. OUTPUTFORMAT png has
> IMAGEMODE RGB/RGBA, which is not supported for GD drivers.
> When I installed for the first time MapServer everything works, but I had
> to reinstall it and I cannot even see my work now.
> I am using Windows Vista and MapServer MS4W - MapServer 4 Windows - version
> 3.0.3: (This is my first time when I am working with MapServer, actually I
> am learning it.)
> The map file that I tried to open is:
> MAP
> NAME "Rail"
> # Map image size
> SIZE 600 400
> UNITS meters
> EXTENT -132.193287 28.711430 -50.854471 74.207982
> FONTSET 'c:/wwwroot/fonts/fontset.txt'
> SYMBOLSET 'c:/wwwroot/symbols/symbols.txt'
> PROJECTION
> 'proj=longlat'
> 'ellps=WGS84'
> 'towgs84=0,0,0,0,0,0,0'
> 'no_defs'
> END
> # Background color for the map canvas -- change as desired
> IMAGECOLOR 255 255 255
> IMAGEQUALITY 95
> IMAGETYPE png
> OUTPUTFORMAT
> NAME png
> DRIVER 'GD/PNG'
> MIMETYPE 'image/png'
> IMAGEMODE RGBA
> EXTENSION 'png'
> END
> # Legend
> LEGEND
> STATUS ON
> KEYSIZE 18 12
> LABEL
> TYPE BITMAP
> SIZE MEDIUM
> COLOR 0 0 89
> END
> END
> # Web interface definition. Only the template parameter
> # is required to display a map. See MapServer documentation
> WEB
> # Set IMAGEPATH to the path where MapServer should
> # write its output.
> IMAGEPATH "\ms4w\tmp\ms_tmp\"
> # Set IMAGEURL to the url that points to IMAGEPATH
> # as defined in your web server configuration
> IMAGEURL "/ms_tmp/"
> # WMS server settings
> METADATA
> 'ows_title' 'Rail'
> 'ows_onlineresource' '
> http://localhost/cgi-bin/mapserv.exe?map=C:/wwwroot/assignment3/rail.map'
> 'ows_srs' 'EPSG:4326'
> END
> #Scale range at which web interface will operate
> # Template and header/footer settings
> # Only the template parameter is required to display a map. See
> TEMPLATE 'rail.html'
> END
> LAYER
> NAME 'Rails'
> TYPE LINE
> DUMP true
> TEMPLATE fooOnlyForWMSGetFeatureInfo
> DATA 'C:\wwwroot\assignment3\rails.shp'
> METADATA
> 'ows_title' 'Rails'
> END
> STATUS DEFAULT
> TRANSPARENCY 100
> PROJECTION
> 'proj=longlat'
> 'ellps=WGS84'
> 'no_defs'
> END
> CLASS
> NAME 'Rails'
> STYLE
> WIDTH 2
> COLOR 146 154 155
> END
> END
> END
> END
> Please, if somebody can help me I will really appreciate. I tried so many
> times and now I really don't know what to do more.
> Thanks.
> mapserver-users at lists.osgeo.org
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20110724/e87a2a06/attachment.html
