[mapserver-users] Problem GetFeature with geom filter on WFS
Stéphane Brunner
stephane.brunner at camptocamp.com
Mon Jul 25 07:19:49 EDT 2011
Hello,
I have the mapfile [0]. when I done a GetFeature on the nummer [1] I
have 4 results [2] (with duplicate but it's an other issue).
When I done a spatial filter [3] I have no results [4] but I should
have at least one result ...
Thanks in advance for having a look on this issue.
Sincerely yours
Stéphane Brunner
Following: specified, GetCapabilities [5], describefeaturetype [6].
mapfile [0]:
MAP
NAME "map"
EXTENT 620000 218000 690000 278000
UNITS METERS
IMAGETYPE jpeg
RESOLUTION 72
DEFRESOLUTION 72
IMAGECOLOR 255 255 255
STATUS ON
FONTSET "fonts.conf"
SYMBOLSET "symbole.sym"
MAXSIZE 5000
PROJECTION
"init=epsg:21781"
END
# Used by overlays
OUTPUTFORMAT
NAME png256
DRIVER AGG/PNG
MIMETYPE "image/png256"
IMAGEMODE RGBA
EXTENSION "png"
FORMATOPTION "INTERLACE=OFF"
FORMATOPTION "QUANTIZE_FORCE=ON"
FORMATOPTION "QUANTIZE_DITHER=OFF"
FORMATOPTION "QUANTIZE_COLORS=256"
END
OUTPUTFORMAT
NAME png
DRIVER AGG/PNG
MIMETYPE "image/png"
IMAGEMODE RGBA
EXTENSION "png"
END
WEB
METADATA
"ows_title" "map"
"ows_srs" "epsg:21781"
"ows_encoding" "UTF-8"
"wms_feature_info_mime_type" "application/vnd.ogc.gml"
"wms_enable_request" "*"
"ows_enable_request" "*"
"gml_include_items" "all"
"gml_featureid" "id"
"wfs_title" "map"
"wfs_srs" "epsg:21781"
END
IMAGEPATH '/var/tmp/'
END
LEGEND
IMAGECOLOR 240 240 240
LABEL
FONT arial
ANTIALIAS true
TYPE truetype
SIZE 9
COLOR 0 0 0
END
END
LAYER
NAME "Liegenschaft_Query"
TYPE POLYGON
STATUS ON
TEMPLATE fooOnlyForWMSGetFeatureInfo
CONNECTIONTYPE postgis
PROCESSING "CLOSE_CONNECTION=DEFER"
CONNECTION "user=www-data password=www-data dbname=dev host=localhost"
DATA "geom from (SELECT oid, t1.geom, t1.nummer FROM
av.view_i_liegenschaft_all AS t1) AS foo using unique oid using
SRID=-1"
# GROUP "TOPIC_Liegenschaften_LN"
METADATA
"ows_title" "Liegenschaft_Query"
"id_attribute_string" "oid"
"ows_featureid" "oid"
"ows_geometries" "geom"
"ows_geom_type" "polygon"
"query_returned_attributes" "nummer"
"gml_include_items" "oid,nummer,geom"
"gml_geometries" "geom"
"gml_geom_type" "polygon"
"gml_nummer_type" "Character"
#"gml_groups" "TOPIC_Liegenschaften_LN"
"gml_featureid" "oid"
"wfs_title" "Liegenschaft_Query"
END
DUMP TRUE
PROJECTION
"init=epsg:21781"
END
CLASS
NAME "Liegenschaft"
STYLE
SYMBOL "circle"
SIZE 3
OUTLINECOLOR 0 0 0
END
END
END
END
query on the nummer [1]:
<wfs:GetFeature xmlns:wfs="http://www.opengis.net/wfs" service="WFS"
version="1.0.0" maxFeatures="100"
xsi:schemaLocation="http://www.opengis.net/wfs
http://schemas.opengis.net/wfs/1.0.0/WFS-transaction.xsd"
xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance">
<wfs:Query typeName="feature:Liegenschaft_Query"
xmlns:feature="http://mapserver.gis.umn.edu/mapserver">
<ogc:Filter xmlns:ogc="http://www.opengis.net/ogc">
<ogc:PropertyIsEqualTo>
<ogc:PropertyName>nummer</ogc:PropertyName>
<ogc:Literal>3634</ogc:Literal>
</ogc:PropertyIsEqualTo>
</ogc:Filter>
</wfs:Query>
</wfs:GetFeature>
response on the nummer [2]:
<?xml version='1.0' encoding="UTF-8" ?>
<wfs:FeatureCollection
xmlns:ms="http://mapserver.gis.umn.edu/mapserver"
xmlns:gml="http://www.opengis.net/gml"
http://schemas.opengis.net/wfs/1.0.0/WFS-basic.xsd
http://c2cpc89.camptocamp.com/sbrunner/mapserv?SERVICE=WFS&VERSION=1.0.0&REQUEST=DescribeFeatureType&TYPENAME=feature:Liegenschaft_Query&OUTPUTFORMAT=XMLSCHEMA">
<gml:boundedBy>
<gml:Box srsName="EPSG:21781">
<gml:coordinates>661054.808000,244611.321000
663053.704000,244888.622000</gml:coordinates>
</gml:Box>
</gml:boundedBy>
<gml:featureMember>
<ms:Liegenschaft_Query fid="Liegenschaft_Query.2380997">
<gml:boundedBy>
<gml:coordinates>661054.808000,244854.251000
661088.687000,244888.622000</gml:coordinates>
</gml:Box>
</gml:boundedBy>
<ms:geom>
<gml:Polygon srsName="EPSG:21781">
<gml:outerBoundaryIs>
<gml:LinearRing>
<gml:coordinates>661076.579000,244888.622000
661054.808000,244875.484000 661062.744000,244858.448000
661064.653000,244854.251000 661088.687000,244869.173000
661076.579000,244888.622000 </gml:coordinates>
</gml:LinearRing>
</gml:outerBoundaryIs>
</gml:Polygon>
</ms:geom>
<ms:oid>2380997</ms:oid>
<ms:nummer>3634</ms:nummer>
</ms:Liegenschaft_Query>
</gml:featureMember>
<gml:featureMember>
<gml:boundedBy>
</gml:Box>
</gml:boundedBy>
<ms:geom>
<gml:LinearRing>
</gml:LinearRing>
</gml:Polygon>
</ms:geom>
<gml:featureMember>
<ms:Liegenschaft_Query fid="Liegenschaft_Query.2384539">
<gml:boundedBy>
<gml:coordinates>663017.565000,244611.321000
663053.704000,244650.084000</gml:coordinates>
</gml:Box>
</gml:boundedBy>
<ms:geom>
<gml:LinearRing>
<gml:coordinates>663017.565000,244635.722000
663033.235000,244611.321000 663045.949000,244619.485000
663053.704000,244626.417000 663034.337000,244650.084000
663017.565000,244635.722000 </gml:coordinates>
</gml:LinearRing>
</gml:Polygon>
</ms:geom>
<ms:oid>2384539</ms:oid>
<gml:featureMember>
<gml:boundedBy>
</gml:Box>
</gml:boundedBy>
<ms:geom>
<gml:LinearRing>
</gml:LinearRing>
</gml:Polygon>
</ms:geom>
</wfs:FeatureCollection>
query with spatial filter [3]:
<ogc:Intersects>
<ogc:PropertyName>geom</ogc:PropertyName>
<gml:Point xmlns:gml="http://www.opengis.net/gml" srsName="EPSG:21781">
<gml:coordinates decimal="." cs="," ts="
">661070.024,244872.084</gml:coordinates>
</gml:Point>
</ogc:Intersects>
</ogc:Filter>
</wfs:Query>
</wfs:GetFeature>
response with spatial filter [4]:
<gml:boundedBy>
<gml:null>missing</gml:null>
</gml:boundedBy>
GetCapabilities [5]:
<WFS_Capabilities
version="1.0.0"
updateSequence="0"
xmlns="http://www.opengis.net/wfs"
http://schemas.opengis.net/wfs/1.0.0/WFS-capabilities.xsd">
<!-- MapServer version 6.0.0 OUTPUT=GIF OUTPUT=PNG OUTPUT=JPEG
SUPPORTS=PROJ SUPPORTS=AGG SUPPORTS=CAIRO SUPPORTS=OPENGL
SUPPORTS=FREETYPE SUPPORTS=ICONV SUPPORTS=FRIBIDI SUPPORTS=WMS_SERVER
SUPPORTS=WMS_CLIENT SUPPORTS=WFS_SERVER SUPPORTS=WFS_CLIENT
SUPPORTS=WCS_SERVER SUPPORTS=SOS_SERVER SUPPORTS=FASTCGI
SUPPORTS=THREADS SUPPORTS=GEOS INPUT=POSTGIS INPUT=OGR INPUT=GDAL
INPUT=SHAPEFILE -->
<Service>
<Name>MapServer WFS</Name>
<Title>Amtliche Vermessung</Title>
<Abstract>Die amtliche Vermessung nach DM01 Darstellung als WMS
Dienst für MapFish Projekte</Abstract>
<OnlineResource>http://c2cpc89.camptocamp.com/sbrunner/mapserv?</OnlineResource>
</Service>
<Capability>
<Request>
<GetCapabilities>
<DCPType>
<HTTP>
<Get onlineResource="http://c2cpc89.camptocamp.com/sbrunner/mapserv?"
</HTTP>
</DCPType>
<DCPType>
<HTTP>
<Post
onlineResource="http://c2cpc89.camptocamp.com/sbrunner/mapserv?" />
</HTTP>
</DCPType>
</GetCapabilities>
<DescribeFeatureType>
<SchemaDescriptionLanguage>
<XMLSCHEMA/>
</SchemaDescriptionLanguage>
<DCPType>
<HTTP>
</HTTP>
</DCPType>
<DCPType>
<HTTP>
<Post
</HTTP>
</DCPType>
</DescribeFeatureType>
<GetFeature>
<ResultFormat>
<GML2/>
</ResultFormat>
<DCPType>
<HTTP>
</HTTP>
</DCPType>
<DCPType>
<HTTP>
<Post
</HTTP>
</DCPType>
</GetFeature>
</Request>
</Capability>
<FeatureTypeList>
<Operations>
<Query/>
</Operations>
<FeatureType>
<Name>Liegenschaft_Query</Name>
<Title>Liegenschaft_Query</Title>
<SRS>epsg:21781</SRS>
<LatLongBoundingBox minx="620000" miny="218000" maxx="690000"
maxy="278000" />
</FeatureType>
<FeatureType>
<Name>Liegenschaft_Query_ALL</Name>
<Title>Liegenschaft_Query_ALL</Title>
maxy="278000" />
</FeatureType>
</FeatureTypeList>
<ogc:Filter_Capabilities>
<ogc:Spatial_Capabilities>
<ogc:Spatial_Operators>
<ogc:Equals/>
<ogc:Disjoint/>
<ogc:Touches/>
<ogc:Within/>
<ogc:Overlaps/>
<ogc:Crosses/>
<ogc:Intersect/>
<ogc:Contains/>
<ogc:DWithin/>
<ogc:BBOX/>
</ogc:Spatial_Operators>
</ogc:Spatial_Capabilities>
<ogc:Scalar_Capabilities>
<ogc:Logical_Operators />
<ogc:Comparison_Operators>
<ogc:Simple_Comparisons />
<ogc:Like />
<ogc:Between />
</ogc:Comparison_Operators>
</ogc:Scalar_Capabilities>
</ogc:Filter_Capabilities>
</WFS_Capabilities>
describefeaturetype [6]:
<schema
targetNamespace="http://mapserver.gis.umn.edu/mapserver"
xmlns:xsd="http://www.w3.org/2001/XMLSchema"
xmlns="http://www.w3.org/2001/XMLSchema"
elementFormDefault="qualified" version="0.1" >
<import namespace="http://www.opengis.net/gml"
schemaLocation="http://schemas.opengis.net/gml/2.1.2/feature.xsd" />
<element name="Liegenschaft_Query"
type="ms:Liegenschaft_QueryType"
substitutionGroup="gml:_Feature" />
<complexType name="Liegenschaft_QueryType">
<complexContent>
<extension base="gml:AbstractFeatureType">
<sequence>
<element name="geom" type="gml:PolygonPropertyType"
minOccurs="0" maxOccurs="1"/>
<element name="oid" type="string"/>
<element name="nummer" type="Character"/>
</sequence>
</extension>
</complexContent>
</complexType>
</schema>
camptocamp.com
mapfish.org
