[mapserver-users] Possible Bug? use Style with Offset and Color
from DB twice in one class section
Steve Lime
sdlime at gmail.com
Wed Jul 27 22:14:45 EDT 2011
What version? I remember fixing something like this at one point... Steve
Sent from my iPad
On Jul 26, 2011, at 4:13 AM, "Ralf Trier" <Ralf.Trier at logos-ib.de> wrote:
> Hello,
> I want to draw two parallel lines to baselines from a database. The
> parallel lines should be drawn with the color set in the db.
> Part of my map file:
> LAYER
> NAME "tttt"
> TYPE LINE
> PROJECTION
> "init=epsg:900913"
> END
> STATUS DEFAULT
> CONNECTIONTYPE postgis
> CONNECTION "host=192.168.1.10 dbname=xxx user=xxx"
> DATA "way from (select id, color01, color02, way from myTable)
> as foo using unique id using srid=900913"
> SIZEUNITS pixels
> CLASS
> STYLE
> OFFSET 5 -99
> COLOR [color01]
> WIDTH 10
> LINECAP square
> END
> STYLE
> OFFSET -5 -99
> COLOR [color02]
> WIDTH 10
> LINECAP square
> END
> END
> END
> Strange think happens. The first parallel line is drawn with the
> expected color. The second line (second style instruction) will be drawn
> in a random color seems to come from another line. The color (second
> line) will change depending form the scale.
> Any ideas?
> Thanks
> Ralf
> mapserver-users at lists.osgeo.org
