[mapserver-users] display labels as an integer instead of
scientific notations [SEC=UNCLASSIFIED]
Mark Volz
MarkVolz at co.lyon.mn.us
Fri Jul 29 09:27:40 EDT 2011
Kathleen,
That works quite well Thank you!
Mark Volz
GIS Specialist
Lyon County, MN
507-532-8218
From: Kathleen Hirst [mailto:K.Hirst at bom.gov.au]
Sent: Thursday, July 28, 2011 7:57 PM
To: Mark Volz
Cc: mapserver-users at lists.osgeo.org
Subject: FW: [mapserver-users] display labels as an integer instead of scientific notations [SEC=UNCLASSIFIED]
Hi Mark,
You can use an OGR connection for formatting of number fields when labelling in MapServer version 5.x. I think you need GDAL 1.6 or later.
For example with a shapefile called test.shp with a field, testfld1, you can do the following to show only two decimal places.
LAYER
CONNECTIONTYPE OGR
CONNECTION "test.shp"
DATA "select CAST(testfld1 AS numeric (4,2)) from test"
CLASS
TEXT ([testfld1)]
LABEL
END
END
END
Regards,
Kathleen
From: mapserver-users-bounces at lists.osgeo.org [mailto:mapserver-users-bounces at lists.osgeo.org] On Behalf Of Mark Volz
Sent: Thursday, 28 July 2011 5:26 AM
To: mapserver-users at lists.osgeo.org
Subject: [mapserver-users] display labels as an integer instead of scientific notations.
Hello,
I have a label that displays a number in scientific notation; for example 2.08+e002. I would like the label to display as an integer such as 2.08. In the past I asked a similar question about HTML templates and someone mentioned that I should use "[item name="area" precision=2]" Unfortunately, the statement seems invalid as a label in the .map file.
Does anyone know how I can display a number as an integer? Or will I have to convert all my values to Text? I am using mapserver 5.4
Thanks
Mark
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20110729/37f2cff2/attachment.html
