[mapserver-users] Ticket #3274 - !BOX! parameter handling in
mapscript
Just van den Broecke
just at justobjects.nl
Tue Mar 8 08:03:49 EST 2011
I stumbled across a substitution issue with the !BOX! parameter on
PostGIS layers when using Mapscript, but also found that it may have
been fixed:
http://trac.osgeo.org/mapserver/ticket/3274
The related changeset is not in any release yet, or not that I found,
using MS 5.6.6 (Mac OSX Kyngchaos version) or Ubuntu MS 5.6.3
In my case this issue only happens when doing a layer.queryByRect()
within Python Mapscript on a layerObj. When dispatching via
OWSDispatch() things work as expected.
For which release is ticket #3274 planned or is there some other
workaround (other than building from SVN) ?
My Mapfile snipped is:
DATA "the_geom from (select g.id, g.point as the_geom from gw_tracepoint
g where g.point && !BOX! order by random() limit 3000) as subquery using
unique id using srid=4326"
MS issues the following failing query within layer.queryByRect():
"select * from (select g.id, g.point as the_geom from gw_tracepoint g
where g.point &&!BOX! order by random() limit 3000) as subquery where
false limit 0". This seems to be a "prequery" before doing the real
query. Anyways, !BOX! is not substituted. Is there some way to suppress
this prequery ?
I want to get at most 3000 points within a bbox from a points table,
randomly spread within the bbox. Leaving out !BOX! does not work
properly since the subquery will then get points from the entire
collection and then apply bbox on that set.
Suggestions welcome. Best,
--Just
www.justobjects.nl
