[mapserver-users] wms transparency
Jim White
jbw2003 at earthlink.net
Tue Mar 8 13:14:50 EST 2011
Arlen,
Thanks that helped. However I had to explicitly set my layers to the
same projection.
// override default epsg code
aliasproj = new OpenLayers.Projection("EPSG:3857");
wms.projection = gphy.projection = aliasproj;
Your site looks nice. However, I can't read Dutch so I don't know what
the layers mean.
Jim
On 03/07/2011 05:21 PM, Arlen Poort wrote:
> Jim,
> You might check the code of my page. This has a transparent mapserver
> wms. You can find the code here:
> mapserver.nrc-handelsblad.com/PS2011.html
> Best regards,
> Arlen Poort
> Op maandag 7 maart 2011 schreef Jim White (jbw2003 at earthlink.net) het volgende:
>> I have a MapServer WMS server and I want to overlay its layers on a Google map WMS layer in OpenLayers.
>> I have tried to follow the example http://openlayers.org/dev/examples/layer-opacity.html , but am unable to get any transparency. All I get is a less bright layer.
>> var options2 = {
>> maxExtent: new OpenLayers.Bounds(-7564972, 2022817, -7260079, 2099643),
>> units: 'm',
>> projection: "EPSG:3857",
>> maxScale: 2000000
>> var map;
>> var wms;
>> var gphy;
>> $(document).ready(function() {
>> map = new OpenLayers.Map('map', options2);
>> wms = new OpenLayers.Layer.WMS( "OpenLayers WMS",
>> "http://metacomet.zo.ncsu.edu/wms/prgap.php",
>> {layers: 'pd009', format: "image/png", srs: "EPSG:3857"},
>> { opacity: 0.3}
>> gphy = new OpenLayers.Layer.Google(
>> "Google Physical",
>> {type: google.maps.MapTypeId.TERRAIN, //sphericalMercator: true,
>> 'maxExtent': new OpenLayers.Bounds(-7564972, 2022817, -7260079, 2099643)
>> map.addLayer(wms);
>> map.addLayer( gphy);
>> map.zoomToMaxExtent();
>> Wil appreciate any suggestions for my MapServer config or OpenLayers script.
>> Jim
>> mapserver-users mailing list
>> mapserver-users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapserver-users
