[mapserver-users] Symbol not showing up in MapServer 6.0.0-beta1
release
thomas bonfort
thomas.bonfort at gmail.com
Fri Mar 11 06:17:20 EST 2011
huh, I may have misinterpreted...
you can't expect to obtain a point/marker symbology when using a line geometry.
if you effectively want to use marker symbols, you can have a look RFC
48 and its
GEOMTRANSFORM "start|end|vertices" transformations.
thomas
On Fri, Mar 11, 2011 at 12:10, thomas bonfort <thomas.bonfort at gmail.com> wrote:
> Phil,
> what kind of symbology are you trying to obtain. I suspect you're
> aiming for a thick line, which now does not require the use of a
> symbol, but rather:
> style
> width 20
> color 0 0 255
> end
> regards,
> thomas
> On Fri, Mar 11, 2011 at 02:24, Anzel, Phil - Fort Collins, CO
> <Phil.Anzel at ftc.usda.gov> wrote:
>> All,
>> I upgraded to MapServer 5.7 (6.0.0-beta1) code for x32/VS2010 (downloaded from http://vbkto.dyndns.org/sdk/) on March 9, 2011.
>> It appears that embedded symbols are not drawn. Below is a simple map file that has a single diagonal line as a feature and two styles; the first should draw a 25-pixel circle, the second a single-pixel line; similar map files worked under 5.6.3. I do not know if this worked under 5.7 circa December 15, 2010.
>> Only the single-pixel line is drawn. I've tried various other symbol definitions; none appear in the output.
>> I'm using the "drawmap.exe" utility to draw the PNG output file under Microsoft Windows XP Professional 2002 SP 3. No errors are reported.
>> Can you help?
>> Thanks,
>> - Phil Anzel
>> Web Soil Survey development team
>> Vistronix Inc. for USDA/NRCS/ITC
>> ..... start of map file .....
>> MAP
>> OUTPUTFORMAT
>> NAME 'pnga'
>> MIMETYPE 'image/pnga'
>> DRIVER 'AGG/PNG'
>> EXTENSION 'png'
>> IMAGEMODE 'RGBA'
>> TRANSPARENT TRUE
>> FORMATOPTION 'INTERLACE=OFF'
>> END
>> STATUS ON
>> SIZE 954 589
>> EXTENT -11760744.430293 5057510.78178777 -11752931.9172644 5062334.23060729
>> RESOLUTION 70
>> UNITS METERS
>> IMAGECOLOR 255 255 255
>> PROJECTION 'proj=merc' 'a=6378137' 'b=6378137' 'lat_ts=0.0' 'lon_0=0.0' 'x_0=0.0' 'y_0=0' 'k=1.0' 'units=m' 'nadgrids=@null' 'north' 'no_defs' END
>> symbol
>> name 'circle' filled true type ellipse points 0 0 1 1 end
>> end
>> LAYER
>> NAME 'single line'
>> STATUS ON
>> TYPE LINE
>> feature points -11760750 5057520 -11752920 5062330 end end
>> CLASS
>> style
>> symbol 'circle'
>> size 20
>> color 255 255 0
>> outlinecolor 255 0 0
>> end
>> style
>> width 1
>> color 0 0 255
>> end
>> end
>> END # end of layer 'single line'
>> END # end of MAP
>> ..... end of map file .....
>> mapserver-users mailing list
>> mapserver-users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapserver-users
