[mapserver-users] Symbol not showing up in MapServer 6.0.0-beta1
release
thomas bonfort
thomas.bonfort at gmail.com
Fri Mar 11 06:10:54 EST 2011
Phil,
what kind of symbology are you trying to obtain. I suspect you're
aiming for a thick line, which now does not require the use of a
symbol, but rather:
style
width 20
color 0 0 255
end
regards,
thomas
On Fri, Mar 11, 2011 at 02:24, Anzel, Phil - Fort Collins, CO
<Phil.Anzel at ftc.usda.gov> wrote:
> All,
> I upgraded to MapServer 5.7 (6.0.0-beta1) code for x32/VS2010 (downloaded from http://vbkto.dyndns.org/sdk/) on March 9, 2011.
> It appears that embedded symbols are not drawn. Below is a simple map file that has a single diagonal line as a feature and two styles; the first should draw a 25-pixel circle, the second a single-pixel line; similar map files worked under 5.6.3. I do not know if this worked under 5.7 circa December 15, 2010.
> Only the single-pixel line is drawn. I've tried various other symbol definitions; none appear in the output.
> I'm using the "drawmap.exe" utility to draw the PNG output file under Microsoft Windows XP Professional 2002 SP 3. No errors are reported.
> Can you help?
> Thanks,
> - Phil Anzel
> Web Soil Survey development team
> Vistronix Inc. for USDA/NRCS/ITC
> ..... start of map file .....
> MAP
> OUTPUTFORMAT
> NAME 'pnga'
> MIMETYPE 'image/pnga'
> DRIVER 'AGG/PNG'
> EXTENSION 'png'
> IMAGEMODE 'RGBA'
> TRANSPARENT TRUE
> FORMATOPTION 'INTERLACE=OFF'
> END
> STATUS ON
> SIZE 954 589
> EXTENT -11760744.430293 5057510.78178777 -11752931.9172644 5062334.23060729
> RESOLUTION 70
> UNITS METERS
> IMAGECOLOR 255 255 255
> PROJECTION 'proj=merc' 'a=6378137' 'b=6378137' 'lat_ts=0.0' 'lon_0=0.0' 'x_0=0.0' 'y_0=0' 'k=1.0' 'units=m' 'nadgrids=@null' 'north' 'no_defs' END
> symbol
> name 'circle' filled true type ellipse points 0 0 1 1 end
> end
> LAYER
> NAME 'single line'
> STATUS ON
> TYPE LINE
> feature points -11760750 5057520 -11752920 5062330 end end
> CLASS
> style
> symbol 'circle'
> size 20
> color 255 255 0
> outlinecolor 255 0 0
> end
> style
> width 1
> color 0 0 255
> end
> end
> END # end of layer 'single line'
> END # end of MAP
> ..... end of map file .....
> mapserver-users at lists.osgeo.org
