[mapserver-users] Symbol not showing up in MapServer 6.0.0-beta1
release
Anzel, Phil - Fort Collins, CO
Phil.Anzel at ftc.usda.gov
Thu Mar 10 20:24:18 EST 2011
All,
I upgraded to MapServer 5.7 (6.0.0-beta1) code for x32/VS2010 (downloaded from http://vbkto.dyndns.org/sdk/) on March 9, 2011.
It appears that embedded symbols are not drawn. Below is a simple map file that has a single diagonal line as a feature and two styles; the first should draw a 25-pixel circle, the second a single-pixel line; similar map files worked under 5.6.3. I do not know if this worked under 5.7 circa December 15, 2010.
Only the single-pixel line is drawn. I've tried various other symbol definitions; none appear in the output.
I'm using the "drawmap.exe" utility to draw the PNG output file under Microsoft Windows XP Professional 2002 SP 3. No errors are reported.
Can you help?
Thanks,
- Phil Anzel
Web Soil Survey development team
Vistronix Inc. for USDA/NRCS/ITC
..... start of map file .....
MAP
OUTPUTFORMAT
NAME 'pnga'
MIMETYPE 'image/pnga'
DRIVER 'AGG/PNG'
EXTENSION 'png'
IMAGEMODE 'RGBA'
TRANSPARENT TRUE
FORMATOPTION 'INTERLACE=OFF'
END
STATUS ON
SIZE 954 589
EXTENT -11760744.430293 5057510.78178777 -11752931.9172644 5062334.23060729
RESOLUTION 70
UNITS METERS
IMAGECOLOR 255 255 255
PROJECTION 'proj=merc' 'a=6378137' 'b=6378137' 'lat_ts=0.0' 'lon_0=0.0' 'x_0=0.0' 'y_0=0' 'k=1.0' 'units=m' 'nadgrids=@null' 'north' 'no_defs' END
symbol
name 'circle' filled true type ellipse points 0 0 1 1 end
end
LAYER
NAME 'single line'
STATUS ON
TYPE LINE
feature points -11760750 5057520 -11752920 5062330 end end
CLASS
style
symbol 'circle'
size 20
color 255 255 0
outlinecolor 255 0 0
end
style
width 1
color 0 0 255
end
end
END # end of layer 'single line'
END # end of MAP
..... end of map file .....
