[mapserver-users] Mapserver as back-end for Google custom
streetview?
Mark Korver
mwkorver at gmail.com
Fri Mar 18 10:31:25 EDT 2011
if you purpose is to replace the google base layer with something
different this might help
http://wiki.openstreetmap.org/wiki/Google_Maps_Example#Example_Using_Google_Maps_API_V3
that allows you to use OSM as basemap.
To use MapServer behind this rather than just getting from OSM, or
CloudMade etc, you need to be able to serve Tiles from MapServer.
see here for how to do that
http://mapserver.org/output/tile_mode.html
The references here are for GMap v2 so you will have to adapt the
examples abit to work with GMap V3
On Fri, Mar 18, 2011 at 7:22 AM, Jan Martin
<janmartin at diy-streetview.org> wrote:
> Hi all,
> I just published 200 panoramas I shot myself using the latest Google custom
> streetview API v3:
> http://www.diy-streetview.org/2011/03/17/google-streetview-player-for-diy-streetviews/
> For this i added an overview map using div's.
> My camera used to shoot the 200 streetviews while walking, without even
> stopping, in just 20 minutes:
> http://www.diy-streetview.com
> I am looking for help to implement a back-end using http://mapserver.org.
> Any sugestions how to do this?
> Thanks,
> Jan Martin
> janmartin AT diy-streetview DOT org
> P.S.:
> Google custom streetview API:
> http://code.google.com/apis/maps/documentation/javascript/services.html#CustomStreetView
> http://www.DIY-streetview.org
> mapserver-users at lists.osgeo.org
