[mapserver-users] MapServer 6.0.0-beta2 release: problems building Java MapScript
Lime, Steve D (DNR) Steve.Lime at state.mn.us
Sat Mar 19 06:55:51 PDT 2011
Changes should go into trunk... Steve
________________________________________
From: mapserver-users-bounces at lists.osgeo.org [mapserver-users-bounces at lists.osgeo.org] On Behalf Of Umberto Nicoletti [umberto.nicoletti at gmail.com]
Sent: Saturday, March 19, 2011 5:37 AM
To: peter.hopfgartner at r3-gis.com; Daniel Morissette
Cc: mapserver-users
Subject: Re: Re: [mapserver-users] MapServer 6.0.0-beta2 release: problems      building Java MapScript
I'm still working on it as it seems there is a memory problem (the tests crash consistently), but unless you create map, layers and other object programmatically you should be fine.
@daniel: where should I commit the changes?
Cheers,
Umberto
On Sat, Mar 19, 2011 at 11:19 AM, Peter Hopfgartner <peter.hopfgartner at r3-gis.com<mailto:peter.hopfgartner at r3-gis.com>> wrote:
Seems good.
Thanks,
Peter
R3 GIS Srl - GmbH
http://www.r3-gis.com
--------Umberto Nicoletti <umberto.nicoletti at gmail.com<mailto:umberto.nicoletti at gmail.com>> wrote--------
Subject: Re: [mapserver-users] MapServer 6.0.0-beta2 release: problems building Java MapScript
Date: 19.03.2011 09:59
>Try the attached patch and if it works I will commit the changes.
>The Makefile.in for java mapscript is probaly missing other defines from
>the
>main Makefile, I'm looking into it right now.
>Regards,
>Umberto
>On Sat, Mar 19, 2011 at 9:19 AM, Peter Hopfgartner <
>> On CentOS 5.5:
>> After running
>> ./configure --with-gd --with-zlib --with-tiff --with-freetype
>--with-gdal
>> --with-ogr --with-geos --with-proj --with-sos --with-wfs --with-wcs
>> --with-wmsclient --with-wfsclient --with-xpm --with-agg --with-cairo
>> --with-postgis --with-curl-config --with-xml2-config --with-threads
>> --enable-debug
>> in mapscript/java/Makefile I've found the following, which causes some
>> troubles afterwards:
>> AGG=     @AGG_ENABLED@
>> AGG_INC=  -Irenderers/agg/include
>> PDF_INC=  @PDF_INC@
>> PDF_LIB=  @PDF_LIB@
>> PDF=      @PDF_ENABLED@
>> I have the same situation with Ubuntu 10.04 on current SVN, as of now.
>> Unfortunatly my autoconf skills are very low, so I not really know how
>to
>> provide a fix or better diagnosis.
>> Peter
>> R3 GIS Srl - GmbH
>> --------Daniel Morissette <dmorissette at mapgears.com<mailto:dmorissette at mapgears.com>> wrote--------
>> Subject: [mapserver-users] MapServer 6.0.0-beta2 release
>> Date: 18.03.2011 20:48
>> >Thanks to the hard work from everyone during the Montreal Code Sprint
>> >this week (http://wiki.osgeo.org/wiki/Montreal_Code_Sprint_2011), the
>> >MapServer Team is pleased to announce the release of MapServer
>> >6.0.0-beta2. This is the latest beta on our way to a final 6.0
>release,
>> >and includes a large number of fixes made during the Montreal Code
>> >Sprint.
>> >The 6.0 release introduces important changes in key components of the
>> >MapServer core (rendering, query and expressions), and for this reason
>> >we count on you, MapServer power users, to help test the release in
>your
>> >respective environments and provide feedback (through the users list
>or
>> >Trac tickets).
>> >This is the second of four planned beta releases and if all goes well
>a
>> >final release should occur around the end of April. The full release
>> >plan which also includes the list of new features and changes in this
>> >release is available at:
>http://mapserver.org/trunk/development/release/release-plan-6.0.html
>> >The list of fixes since beta1 is attached at the end of this message.
>> >For a complete list see the HISTORY.TXT file at:
>http://trac.osgeo.org/mapserver/browser/tags/rel-6-0-0-beta2/mapserver/HISTORY.TXT
>> >We have started working on a 5.6 -> 6.0 migration guide. This document
>> >contains important notes on backwards incompatibilities or other
>changes
>> >required when upgrading to 6.0. It is not complete yet but we strongly
>> >recommend that you review the latest version online at:
>> >     http://mapserver.org/trunk/MIGRATION_GUIDE.html
>> >The source for this release can be downloaded at:
>> >     http://mapserver.org/download.html
>> >or
>> >     http://download.osgeo.org/mapserver/mapserver-6.0.0-beta2.tar.gz
>> >The binary distributions listed in the download page should be updated
>> >with binaries for the new beta release in the next day or so.
>> >Once again we need your help to ensure a high quality product, so
>please
>> >help out by testing your applications with this new code base.
>> >Thanks! - The MapServer Team
>> >Version 6.0.0-beta2 (2011-03-18)
>> >- correct scaling of symbol GAP and PATTERN (#3752)
>> >- remove references to SWF/MING
>> >- CGI runtime substitution requires a validation pattern (was optional
>> >   before) (#3522)
>> >- add a default png8 outputformat that uses AGG/PNG with quantization
>> >- change MS_INIT_COLOR to take alpha as a parameter
>> >- stop using style->opacity in rendering code, use alpha from
>colorObjs.
>> >- Fixed big Oracle memory leak when rendering in KML (#3719)
>> >- avoid linking in postgres dependencies unnecessarily (#3708)
>> >- don't initialize outputformats until they are selected
>> >- use "seamless" creation of tiles for polygon fills with vector
>symbols
>> >- Ability to escape single/double quotes inside a string (#3706)
>> >- Globally replace msCaseFindSubstring with strcasestr (#3255)
>> >- support GROUP layers in shp2img (#3746)
>> >- Honour MAXSIZE for WCS 2.0 responses (#3204).
>> >- fallback to ows_title for WCS ows:Title of CoverageDescription
>(#3528)
>> >- Added msIO_stripStdoutBufferContentHeaders() to strip off all
>> >   Content-* headers from a buffer (#3673, #3665).
>> >- Added raster classification support for STYLE level OPACITY.
>> >- Allow attribute references, that is [itemname], within a TEXT string
>> >(#3736)
>> >- Fixed segmentation fault when parsing invalid extent arguments in
>> >   shp2img (#3734)
>> >- Make "openlayers mode" work even without OWS support (#3732)
>> >- Add a static table to define the axis order for soem epsg codes
>(#3582)
>> >- Add possibility to use KML_NAME_ITEM (#3728)
>> >- Fixed mapfile parsing error when a label angle referenced an
>attribute
>> >   (e.g. ANGLE [angle]) #3727
>> >- Removed executable flag on some source files (#3726)
>> >- Fixed SQL Spatial to be able to use UniqueIdentifier field as unique
>> >   key (#3722)
>> >- Fix PHP Windows build (#3714)
>> >- Fixed --with-opengl build issue: Look for OpenGL libs under
>/usr/lib64
>> >as
>> >   well (#3724)
>> >_______________________________________________
>> >mapserver-users mailing list
>> >mapserver-users at lists.osgeo.org<mailto:mapserver-users at lists.osgeo.org>
>> >http://lists.osgeo.org/mailman/listinfo/mapserver-users
More information about the MapServer-users mailing list
