[mapserver-users] MapServer 6.0.0-beta2 release: problems building Java MapScript
Umberto Nicoletti
umberto.nicoletti at gmail.com
Sat Mar 19 04:07:23 PDT 2011
make test still fails with a SIGSEV in:
C [libmapscript.so+0xd3bfa] msFree+0x23
C [libmapscript.so+0xbdb88] msFreeHashItems+0x9e
C [libmapscript.so+0xfa2f6] msFreeFontSet+0x3f
C [libmapscript.so+0x143711] msFreeMap+0x102
but I can't understand what's going on (have tried memory debuggers without
luck so far).
Has anyone suggestions on what I should be looking into?
Umberto
On Sat, Mar 19, 2011 at 11:37 AM, Umberto Nicoletti <
umberto.nicoletti at gmail.com> wrote:
> I'm still working on it as it seems there is a memory problem (the tests
> crash consistently), but unless you create map, layers and other object
> programmatically you should be fine.
> @daniel: where should I commit the changes?
> Cheers,
> Umberto
> On Sat, Mar 19, 2011 at 11:19 AM, Peter Hopfgartner <
> peter.hopfgartner at r3-gis.com> wrote:
>> Seems good.
>> Thanks,
>> Peter
>> R3 GIS Srl - GmbH
>> http://www.r3-gis.com
>> --------Umberto Nicoletti <umberto.nicoletti at gmail.com> wrote--------
>> Subject: Re: [mapserver-users] MapServer 6.0.0-beta2 release: problems
>> Date: 19.03.2011 09:59
>> >Try the attached patch and if it works I will commit the changes.
>> >The Makefile.in for java mapscript is probaly missing other defines from
>> >the
>> >main Makefile, I'm looking into it right now.
>> >Regards,
>> >Umberto
>> >On Sat, Mar 19, 2011 at 9:19 AM, Peter Hopfgartner <
>> >> On CentOS 5.5:
>> >> After running
>> >> ./configure --with-gd --with-zlib --with-tiff --with-freetype
>> >--with-gdal
>> >> --with-ogr --with-geos --with-proj --with-sos --with-wfs --with-wcs
>> >> --with-wmsclient --with-wfsclient --with-xpm --with-agg --with-cairo
>> >> --with-postgis --with-curl-config --with-xml2-config --with-threads
>> >> --enable-debug
>> >> in mapscript/java/Makefile I've found the following, which causes some
>> >> troubles afterwards:
>> >> AGG= @AGG_ENABLED@
>> >> AGG_INC= -Irenderers/agg/include
>> >> PDF_INC= @PDF_INC@
>> >> PDF_LIB= @PDF_LIB@
>> >> PDF= @PDF_ENABLED@
>> >> I have the same situation with Ubuntu 10.04 on current SVN, as of now.
>> >> Unfortunatly my autoconf skills are very low, so I not really know how
>> >to
>> >> provide a fix or better diagnosis.
>> >> Peter
>> >> R3 GIS Srl - GmbH
>> >> --------Daniel Morissette <dmorissette at mapgears.com> wrote--------
>> >> Subject: [mapserver-users] MapServer 6.0.0-beta2 release
>> >> Date: 18.03.2011 20:48
>> >> >Thanks to the hard work from everyone during the Montreal Code Sprint
>> >> >this week (http://wiki.osgeo.org/wiki/Montreal_Code_Sprint_2011), the
>> >> >MapServer Team is pleased to announce the release of MapServer
>> >> >6.0.0-beta2. This is the latest beta on our way to a final 6.0
>> >release,
>> >> >and includes a large number of fixes made during the Montreal Code
>> >> >Sprint.
>> >> >The 6.0 release introduces important changes in key components of the
>> >> >MapServer core (rendering, query and expressions), and for this reason
>> >> >we count on you, MapServer power users, to help test the release in
>> >your
>> >> >respective environments and provide feedback (through the users list
>> >or
>> >> >Trac tickets).
>> >> >This is the second of four planned beta releases and if all goes well
>> >a
>> >> >final release should occur around the end of April. The full release
>> >> >plan which also includes the list of new features and changes in this
>> >> >release is available at:
>> >http://mapserver.org/trunk/development/release/release-plan-6.0.html
>> >> >The list of fixes since beta1 is attached at the end of this message.
>> >> >For a complete list see the HISTORY.TXT file at:
>> http://trac.osgeo.org/mapserver/browser/tags/rel-6-0-0-beta2/mapserver/HISTORY.TXT
>> >> >We have started working on a 5.6 -> 6.0 migration guide. This document
>> >> >contains important notes on backwards incompatibilities or other
>> >changes
>> >> >required when upgrading to 6.0. It is not complete yet but we strongly
>> >> >recommend that you review the latest version online at:
>> >> > http://mapserver.org/trunk/MIGRATION_GUIDE.html
>> >> >The source for this release can be downloaded at:
>> >> > http://mapserver.org/download.html
>> >> >or
>> >> > http://download.osgeo.org/mapserver/mapserver-6.0.0-beta2.tar.gz
>> >> >The binary distributions listed in the download page should be updated
>> >> >with binaries for the new beta release in the next day or so.
>> >> >Once again we need your help to ensure a high quality product, so
>> >please
>> >> >help out by testing your applications with this new code base.
>> >> >Thanks! - The MapServer Team
>> >> >Version 6.0.0-beta2 (2011-03-18)
>> >> >- correct scaling of symbol GAP and PATTERN (#3752)
>> >> >- remove references to SWF/MING
>> >> >- CGI runtime substitution requires a validation pattern (was optional
>> >> > before) (#3522)
>> >> >- add a default png8 outputformat that uses AGG/PNG with quantization
>> >> >- change MS_INIT_COLOR to take alpha as a parameter
>> >> >- stop using style->opacity in rendering code, use alpha from
>> >colorObjs.
>> >> >- Fixed big Oracle memory leak when rendering in KML (#3719)
>> >> >- avoid linking in postgres dependencies unnecessarily (#3708)
>> >> >- don't initialize outputformats until they are selected
>> >> >- use "seamless" creation of tiles for polygon fills with vector
>> >symbols
>> >> >- Ability to escape single/double quotes inside a string (#3706)
>> >> >- Globally replace msCaseFindSubstring with strcasestr (#3255)
>> >> >- support GROUP layers in shp2img (#3746)
>> >> >- Honour MAXSIZE for WCS 2.0 responses (#3204).
>> >> >- fallback to ows_title for WCS ows:Title of CoverageDescription
>> >(#3528)
>> >> >- Added msIO_stripStdoutBufferContentHeaders() to strip off all
>> >> > Content-* headers from a buffer (#3673, #3665).
>> >> >- Added raster classification support for STYLE level OPACITY.
>> >> >- Allow attribute references, that is [itemname], within a TEXT string
>> >> >(#3736)
>> >> >- Fixed segmentation fault when parsing invalid extent arguments in
>> >> > shp2img (#3734)
>> >> >- Make "openlayers mode" work even without OWS support (#3732)
>> >> >- Add a static table to define the axis order for soem epsg codes
>> >(#3582)
>> >> >- Add possibility to use KML_NAME_ITEM (#3728)
>> >> >- Fixed mapfile parsing error when a label angle referenced an
>> >attribute
>> >> > (e.g. ANGLE [angle]) #3727
>> >> >- Removed executable flag on some source files (#3726)
>> >> >- Fixed SQL Spatial to be able to use UniqueIdentifier field as unique
>> >> > key (#3722)
>> >> >- Fix PHP Windows build (#3714)
>> >> >- Fixed --with-opengl build issue: Look for OpenGL libs under
>> >/usr/lib64
>> >> >as
>> >> > well (#3724)
>> >> >_______________________________________________
>> >> >mapserver-users mailing list
>> >> >mapserver-users at lists.osgeo.org
>> >> >http://lists.osgeo.org/mailman/listinfo/mapserver-users
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20110319/6968563c/attachment.htm>
More information about the MapServer-users
