[mapserver-users] template item formatting options and joined table
iomeneandrei
aborruso at tin.it
Mon Mar 28 07:52:27 EDT 2011
Dear all,
I have an ITEMQUERY on a layer with a join object inside (ONE-TO-MANY).
I would like to format the results using template item formatting options.
Is it possible to use them with the items of joined table?
I have applied it using this kind of syntax [item name="relationname_field"
precision="2" commify="2"], but I have this error message:
"Content-type: text/html processItemTag(): Web application error. Item name
(relate_ULM) not found in layer item list. "
"relate_ULM" is the real name of my joined field. If I insert simply
[relate_ULM] in my template I have no error, and I have the list of results.
Thank you,
Andrea
Andrea Borruso
email: aborruso at tin.it
website: http://blog.spaziogis.it
my 2.0 life: http://aborruso.spaziogis.it
feed: http://feeds2.feedburner.com/Tanto
38° 7' 48" N, 13° 21' 9" E
View this message in context: http://osgeo-org.1803224.n2.nabble.com/template-item-formatting-options-and-joined-table-tp6214589p6214589.html
Sent from the Mapserver - User mailing list archive at Nabble.com.
