[mapserver-users] Too many open files...
Lee Meilleur
lee.meilleur at gis.leg.mn
Tue Mar 29 12:37:15 EDT 2011
The problem ended up being an issue with ulimit, the parameters I entered were not taking. I found the page below which seems to have resolved the issue. Thanks again for all of the suggestions.
http://www.xenoclast.org/doc/benchmark/HTTP-benchmarking-HOWTO/node7.html
Lee
-----Original Message-----
From: mapserver-users-bounces at lists.osgeo.org [mailto:mapserver-users-bounces at lists.osgeo.org] On Behalf Of Stephen Woodbridge
Sent: Monday, March 28, 2011 5:05 PM
To: mapserver-users at lists.osgeo.org
Subject: Re: [mapserver-users] Too many open files...
Lee,
I think I have run into this before.
Turn off SELinux if it is running and I bet that is it.
Otherwise, try building mapserver from source, maybe you ahve a library or rpm packaging issue.
-Steve W
On 3/28/2011 5:57 PM, Jim Klassen wrote:
> Are you running anything else significant on the machine?
> It would generally be very difficult for MapServer, running in CGI
> mode, to use up all the open files.
> The only cases I can think of that could be related to MapServer
> serving shapefiles would be (1) FastCGI and a bug that isn't closing
> files. If this is the case, the issue should go away for awhile after
> you restart apache. (2) if you have some sort of tileindex with a
> huge number of items in it or a tileindex that points back to itself.
> Otherwise, I could see this if something else on the machine is using
> up all the file handles (globally or per user).
> Another random thought... is there some interaction with SELinux
> (assuming you have SELinux enforcing)?
> I think you said this behavior was new... if so, has anything changed
> on the machine lately?
> Sorry I can't be more helpful.
> Jim K
> On Mar 28, 2011, at 4:45 PM, Lee Meilleur wrote:
>> Fedora 12 Apache 2.2.14 Prefork MPM
>> ./shp2img: error while loading shared libraries: librx.so.0: cannot
>> open shared object file: No such file or directory (this was news to
>> me)
>> Serving shapefiles only.
>> MapServer version 5.6.3 OUTPUT=GIF OUTPUT=PNG OUTPUT=JPEG OUTPUT=WBMP
>> OUTPUT=SVG SUPPORTS=PROJ SUPPORTS=AGG SUPPORTS=FREETYPE
>> SUPPORTS=ICONV SUPPORTS=WMS_SERVER SUPPORTS=WMS_CLIENT
>> SUPPORTS=WFS_SERVER SUPPORTS=WFS_CLIENT SUPPORTS=WCS_SERVER
>> SUPPORTS=THREADS SUPPORTS=GEOS INPUT=EPPL7 INPUT=POSTGIS INPUT=OGR
>> INPUT=GDAL INPUT=SHAPEFILE
>> Thanks
>> -----Original Message----- From:
>> Woodbridge Sent: Monday, March 28, 2011 4:29 PM To:
>> mapserver-users at lists.osgeo.org Subject: Re: [mapserver-users] Too
>> many open files...
>> On 3/28/2011 5:05 PM, Lee Meilleur wrote:
>>> Hello,
>>> Has anyone run into the error: "Too many open files: couldn't set
>>> child process attributes: /var/www/cgi-bin/mapserv"? This error
>>> shows up in an Apache error_log. A broken image now shows up for
>>> MapServer layers since this started. I've tried changing the ulimits
>>> or the MaxRequestsPerChild for Apache with no luck.
>>> Any other ideas?
>> You probably need to give us more information like:
>> Which OS? Which Apache version? Which Apache MPM module are you
>> using? /var/www/cgi-bin/mapserv -v output?
>> Does this happen when you run shp2img? What are you serving via
>> mapserver? vectors, imagery, database, etc?
>> -Steve W _______________________________________________
>> mapserver-users mailing list mapserver-users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapserver-users
>> _______________________________________________ mapserver-users
