[mapserver-users] WFS Intersect with gml:box
Joaquín Rodriguez-Guerra Urcelay
jrguerra at gmv.com
Wed Mar 30 03:29:42 EDT 2011
Thanks Yewondwossen,
I am going to try to build from source (I have never donde it before) and update the bug :)
Best regards,
Joaquín
De: Yewondwossen Assefa [mailto:yassefa at dmsolutions.ca]
Enviado el: martes, 29 de marzo de 2011 22:33
Para: Joaquín Rodriguez-Guerra Urcelay
CC: mapserver-users at lists.osgeo.org
Asunto: Re: [mapserver-users] WFS Intersect with gml:box
I did check that and It was not working for me either. It is now fixed in trunk and also in the 5.6.x branch.
I have added a bug <http://trac.osgeo.org/mapserver/ticket/3789> [1] on it, so if you have the chance to build from source, please give it a try and update the bug.
best regards,
[1]: http://trac.osgeo.org/mapserver/ticket/3789
On 29/03/2011 1:18 PM, Joaquín Rodriguez-Guerra Urcelay wrote:
Hello list,
I am using a desktop GIS applicatin (uDig) to connect mapserver and display some wfs layers and I am having some trouble when uDig tries to filter features by bounding box.
uDig sends a intersects spatial filter to obtain features in a bounding box:
http://localhost:8080/cgi-bin/mywfs?WIDTH=512&SERVICE=WFS&VERSION=1.0.0&request=getfeature&typename=PositionReal&Filter=
<Filter xmlns="http://www.opengis.net/ogc"<http://www.opengis.net/ogc> xmlns:gml="http://www.opengis.net/gml"<http://www.opengis.net/gml>><Intersects><PropertyName>point</PropertyName>
<gml:Box srsName="WGS84(DD)"><gml:coordinates decimal="." cs="," ts=" ">-100.0,-45.0 100.0,45.0</gml:coordinates>
</gml:Box>
</Intersects>
</Filter>
But it is not working :(
<ServiceExceptionReport version="1.2.0" xsi:schemaLocation="http://www.opengis.net/ogc http://schemas.opengis.net/wfs/1.0.0/OGC-exception.xsd"<http://www.opengis.net/ogchttp:/schemas.opengis.net/wfs/1.0.0/OGC-exception.xsd>>
<ServiceException code="InvalidParameterValue" locator="filter">
msWFSGetFeature(): WFS server error. Invalid or Unsupported FILTER in GetFeature : <Filter xmlns="http://www.opengis.net/ogc"<http://www.opengis.net/ogc> xmlns:gml="http://www.opengis.net/gml"<http://www.opengis.net/gml>><Intersects><PropertyName>point</PropertyName><gml:Box srsName="WGS84(DD)"><gml:coordinates decimal="." cs="," ts=" ">-100.0,-45.0 100.0,45.0</gml:coordinates></gml:Box></Intersects></Filter>
</ServiceException>
</ServiceExceptionReport>
I have checked that the BBOX filter works perfectly ( I just replaced Intersects with BBOX in the above url)
<Filter xmlns="http://www.opengis.net/ogc"<http://www.opengis.net/ogc> xmlns:gml="http://www.opengis.net/gml"<http://www.opengis.net/gml>><BBOX><PropertyName>point</PropertyName>
</gml:Box>
</BBOX>
</Filter>
But I cant make the INTERSECTS operation work. I would really appreciate if someone could point me to any examples of the INTERSECT operation used together with gml:box or Box.
I have seen some examples of intersects used with gml:polygon, but it should work too with box, right??
Thanks for reading!
Joaquín
______________________
This message including any attachments may contain confidential
information, according to our Information Security Management System,
and intended solely for a specific individual to whom they are addressed.
Any unauthorised copy, disclosure or distribution of this message
is strictly forbidden. If you have received this transmission in error,
please notify the sender immediately and delete it.
Este mensaje, y en su caso, cualquier fichero anexo al mismo,
puede contener informacion clasificada por su emisor como confidencial
en el marco de su Sistema de Gestion de Seguridad de la
Informacion siendo para uso exclusivo del destinatario, quedando
prohibida su divulgacion copia o distribucion a terceros sin la
autorizacion expresa del remitente. Si Vd. ha recibido este mensaje
erroneamente, se ruega lo notifique al remitente y proceda a su borrado.
Gracias por su colaboracion.
mapserver-users mailing list
mapserver-users at lists.osgeo.org<mailto:mapserver-users at lists.osgeo.org>
http://lists.osgeo.org/mailman/listinfo/mapserver-users
Assefa Yewondwossen
Software Analyst
Email: yassefa at dmsolutions.ca<mailto:yassefa at dmsolutions.ca>
http://www.dmsolutions.ca/
Phone: (613) 565-5056 (ext 14)
Fax: (613) 565-0925
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20110330/fbc0735d/attachment-0001.html
