[mapserver-users] RE: Overriding MapServer Map File "DATA"
parameter
Lime, Steve D (DNR)
steve.lime at state.mn.us
Tue Mar 29 17:37:37 EDT 2011
Try things outside of OpenLayers first, easier to debug that way. I'll try and whip up a test case in the meantime on my end to verify the syntax.
Steve
From: Asad Ullah [mailto:Asad.Ullah at sigmaspace.com]
Sent: Tuesday, March 29, 2011 1:20 PM
To: Lime, Steve D (DNR)
Subject: RE: Overriding MapServer Map File "DATA" parameter
Steve,
Thanks very much for your quick response. I added validation to my mapfile layer object but still it is not working. anyother suggestion? I am wondering if the syntex "map.layer[Terra250tif]":"DATA terr_ndvi.vrt" I use in openlayer is correct.
Thanks,
Asad
<https://mail.sigmaspace.com/ecp/Customize/www.sigmaspace.com%20>
From: Lime, Steve D (DNR) [steve.lime at state.mn.us]
Sent: Tuesday, March 29, 2011 12:24 PM
To: Asad Ullah; mapserver-users at lists.osgeo.org
You need to set a validation pattern to muck with the DATA attribute. You'd add something like this to your layer definition:
VALIDATION
'data' '^terr_.*\.vrt$'
END
Steve
From: mapserver-users-bounces at lists.osgeo.org [mailto:mapserver-users-bounces at lists.osgeo.org] On Behalf Of Asad Ullah
Sent: Tuesday, March 29, 2011 10:43 AM
To: mapserver-users at lists.osgeo.org
Subject: [mapserver-users] Overriding MapServer Map File "DATA" parameter
List,
I am trying to override virtual raster (.vrt) file defined in mapfile with a different one from a list of vrt files. I am using Opnelayers and Mapserver 5.6.6 to create map. In Openlayers, I have tried:
var Terra250tif = new OpenLayers.Layer.MapServer( "Terra250m_bands1-4-3",
"http://192.225.64.118/cgi-bin/mapserv?",
layers:"Terra250tif","map.layer[Terra250tif]":"DATA terr_ndvi.vrt",
map: '/usr/local/apache/htdocs/mapfiles/rrglobal_terra_250m_2011052jpg.map'
}, {singleTile:false});
The relevant part of the mapfile is:
LAYER
NAME "Terra250_367jpg"
TYPE RASTER
STATUS DEFAULT
OFFSITE 0 0 0
PROJECTION
"init=epsg:4326"
END
DATA "terr_250m_2011052jpg.vrt"
CLASS
STYLE
BACKGROUNDCOLOR 255 255 255
END
END
END
I looked at "mapserver.osgeo.org/cgi/controls.html....." but that did not helped. So, could anyone help with this.
Thanks,
Asad
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20110329/6351195a/attachment.html
