[mapserver-users] WCS Geotiff output issue
Guillaume Loiselle loiselle.guillaume at gmail.com
Fri Nov 4 07:47:33 PDT 2011
I installed MapServer 6.0.1 on Windows XP from MS4W. I cannot give you
access to my MapServer instance but I can show you what "-v" gives me :
MapServer version 6.0.1 OUTPUT=GIF OUTPUT=PNG OUTPUT=JPEG OUTPUT=KML
SUPPORTS=PR
OJ SUPPORTS=AGG SUPPORTS=CAIRO SUPPORTS=FREETYPE SUPPORTS=ICONV
SUPPORTS=FRIBIDI
 SUPPORTS=WMS_SERVER SUPPORTS=WMS_CLIENT SUPPORTS=WFS_SERVER
SUPPORTS=WFS_CLIENT
 SUPPORTS=WCS_SERVER SUPPORTS=SOS_SERVER SUPPORTS=FASTCGI SUPPORTS=THREADS
SUPPO
RTS=GEOS INPUT=JPEG INPUT=POSTGIS INPUT=OGR INPUT=GDAL INPUT=SHAPEFILE
I am able to generate a GeoTiff file through the use of a WMS service (see
attachment : wmsoutput.tif). The request is :
http://localhost/cgi-bin/mapserv.exe?SERVICE=WMS&map=D:/Guillaume/ProjetCourantsGlaces/WCSproblem/2011102811.map&LAYERS=thelayer&VERSION=1.1.1&REQUEST=GetMap&bbox=-67.5,48.922499263758255,-64.6875,50.736455137010665&SRS=EPSG:4326&WIDTH=256&HEIGHT=256&FORMAT=GTiff
However, I cannot do so with a WCS service. I first tried with :
http://localhost/cgi-bin/mapserv.exe?SERVICE=WCS&map=D:/Guillaume/ProjetCourantsGlaces/WCSproblem/2011102811.map&IDENTIFIER=thelayer&VERSION=1.0.0&REQUEST=GetCoverage&BBOX=-67.5,48.922499263758255,-64.6875,50.736455137010665&CRS=EPSG:4326&WIDTH=256&HEIGHT=256&FORMAT=GTiff
, to which I can add :
&RESPONSE_CRS=EPSG:4326
for the same result (since 4326 is my native projection). Said result is
not a tiff file, but an error :
<?xml version='1.0' encoding="ISO-8859-1" ?>
<ServiceExceptionReport version="1.2.0"
xmlns="http://www.opengis.net/ogc" xmlns:xsi="
http://www.w3.org/2001/XMLSchema-instance" xsi:schemaLocation="
http://schemas.opengis.net/wcs/1.0.0/OGC-exception.xsd">
  <ServiceException code="NoApplicableCode"
locator="bbox">msWCSGetCoverage(): WCS server error. Requested BBOX
(-178.835708198757,2803.05273104522,179.552848002437,2906.98474680556) is
outside requested coverage BBOX (-70,45,-55,52)
  </ServiceException>
</ServiceExceptionReport>
This error doesn't make sense to me. Which projection is it using to get
these silly values? Anyway, the BBOX in the request is definitely included
in the extent... Now what if I change the Response_CRS? I would expect it
to give me the same error, since it doesn't affect the requested BBOX. Yet,
this time no error is produced and I obtain a tiff file (see attachment :
wcsoutput.tif). The data is all wrong (0 everywhere), though. And if I open
both WMS and WCS obtained tiffs in QuantumGIS, they appear nowhere near
each other (for the same bbox... yes).
I attached the results of GetCapabilities and DescribeCoverage requests as
well as the MapServer logs (modified to map logs with requests). The data
source is an HDF5 file (see attachment : data.h5). I suspect an issue on
MapServer's side but I would be happy if you could tell me it's all my
fault (and how to fix it).
Oh, a last thing : it may or may not be related. I had issues with the
KML/KMZ WMS outputformats. Results for epsg:4326 and epsg:900913 were
completely different (and wrong, of course). I might open a new discussion
on this subject at some point.
Thank you all for your help.
Guillaume Loiselle
P.S. : If you want to test, know that epsg:900913 is the same as epsg:3857
(which is more likely to be in your epsg reference file).
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20111104/78e5fa24/attachment.htm>
Type: application/octet-stream
Desc: not available
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20111104/78e5fa24/attachment.obj>
Desc: not available
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20111104/78e5fa24/attachment-0001.obj>
Type: text/xml
Desc: not available
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20111104/78e5fa24/attachment.xml>
Type: text/xml
Desc: not available
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20111104/78e5fa24/attachment-0001.xml>
Desc: not available
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20111104/78e5fa24/attachment-0002.obj>
Type: text/xml
Desc: not available
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20111104/78e5fa24/attachment-0002.xml>
Type: image/tiff
Desc: not available
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20111104/78e5fa24/attachment.tif>
Type: image/tiff
Desc: not available
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20111104/78e5fa24/attachment-0001.tif>
More information about the MapServer-users mailing list
