[mapserver-users] WFS with several SRS?
Jeff McKenna jmckenna at gatewaygeomatics.com
Tue Nov 8 05:23:34 PST 2011
Hello,
Some quick notes that may assist you as you travel down this path:
- for any WMS/WFS/OGC mapfiles, I always
   - check my GetCapabilities response in a text editor for any
"Warning" text, if any exist then change the mapfile until all warnings
from GetCapabilities are gone
   - make sure that each layer has a PROJECTION object (the source
projection for that layer)
   - make sure to have a MAP-level PROJECTION object
   - make sure the WEB object's METADATA parameter has a "wms_srs" or
"wfs_srs" or "ows_srs" line that lists/advertises several different
projections (as previously mentioned in another response)
Hope that helps you through your travels.
-jeff
Jeff McKenna
MapServer Consulting and Training Services
http://www.gatewaygeomatics.com/
On 11-11-08 6:37 AM, sulu wrote:
> I would like to offer a WFS-Service which supports several different
> projections.
> ("WFS_SRS"            "EPSG:31254 EPSG:3785 EPSG:4326 EPSG:31284 EPSG:32632
> EPSG:25832 EPSG:21781")
> My mapserver is of version 5.6.6 on a Centos-Box
> MapServer version 5.6.6 OUTPUT=GIF OUTPUT=PNG OUTPUT=JPEG OUTPUT=WBMP
> OUTPUT=SVG SUPPORTS=PROJ SUPPORTS=AGG SUPPORTS=FREETYPE SUPPORTS=ICONV
> SUPPORTS=WMS_SERVER SUPPORTS=WMS_CLIENT SUPPORTS=WFS_SERVER
> SUPPORTS=WFS_CLIENT SUPPORTS=FASTCGI INPUT=EPPL7 INPUT=POSTGIS INPUT=OGR
> INPUT=GDAL INPUT=SHAPEFILE
> As expected the default SRS is 31254.
> A GetFeature-Call with this EPSG works just fine:
> Example:
> http://vogis.cnv.at/cgi-bin/mapserv?map=wfs.map&SERVICE=WFS&VERSION=1.1.0&REQUEST=GetFeature&TYPENAME=nutzungs-grenzen&SRSNAME=epsg:31254
> But if i try a other SRS from the WFS_SRS (e.g. 4326) above i receive:
> msWFSGetFeature(): WFS server error. Invalid GetFeature Request: SRSNAME
> value should be valid for all the TYPENAMES. Please check the capabilities
> and reformulate your request.
> As you can see in the Mapfile below, i avoided specifying any projection in
> the layer section so i have to wonder what i am doing wrong?
> Thanks
> Andy
> MAPFILE
> MAP
> 	EXTENT     -70000 180000 5000 280000		#for EPSG:31254
> 	FONTSET    ./fontset
> 	IMAGETYPE  png
> 	MAXSIZE    8000
> 	RESOLUTION 96
> 	SYMBOLSET  ./etc/symbol/symbols.sym
> 	# Debugging
> 	CONFIG "MS_ERRORFILE" "/tmp/mapserver_wfs_error.txt"
> 	DEBUG 5
> 	WEB
> 		METADATA
> 			"WFS_TITLE"          "DKM Vorarlberg"
> EPSG:32632 EPSG:25832 EPSG:21781"
> 			"WFS_ABSTRACT"       "Geodaten des Bundeslandes Vorarlberg als OGC-WFS"
> 			"WMS_SRS"            "EPSG:4326 EPSG:31254 EPSG:31284 EPSG:32632
> 			"WMS_TITLE"          "DKM Vorarlberg"
> 			"WMS_ABSTRACT"        "Geodaten des Bundeslandes Vorarlberg als OGC-WMS"
> 			#"WMS_ONLINERESOURCE"
> "http://vogis.cnv.at/mapserver/mapserv?map=wfs.map&version=1.1.0"
> 			"WMS_FORMATLIST"      "image/gif,image/png,image/jpeg,image/tif"
> 			"WMS_FEATURE_INFO_MIME_TYPE" "text/html"
> 		END
> 	END
> 	OUTPUTFORMAT
> 		NAME jpg
> 		DRIVER "GDAL/JPEG"
> 		MIMETYPE "image/jpeg"
> 		IMAGEMODE RGB
> 		EXTENSION "jpg"
> 		END
> 	OUTPUTFORMAT
> 		NAME jpg
> 		DRIVER "GDAL/JPEG"
> 		MIMETYPE "image/jpg"
> 		IMAGEMODE RGB
> 		EXTENSION "jpg"
> 		END
> 	OUTPUTFORMAT
> 		NAME gif
> 		DRIVER "GD/GIF"
> 		MIMETYPE "image/gif"
> 		IMAGEMODE PC256
> 		EXTENSION "gif"
> 		END
> 	OUTPUTFORMAT
> 		NAME png
> 		# Driver AGG/PNG weil der GDAL-Driver Probleme bei der Transparenz hat
> 		DRIVER "AGG/PNG"
> 		MIMETYPE "image/png"
> 		IMAGEMODE RGBA
> 		EXTENSION "png"
> 		TRANSPARENT ON
> 		FORMATOPTION "INTERLACE=OFF"
> 	END
> 	OUTPUTFORMAT
> 		NAME wbmp
> 		DRIVER "GD/WBMP"
> 		MIMETYPE "image/wbmp"
> 		IMAGEMODE PC256
> 		EXTENSION "wbmp"
> 	END
> 	OUTPUTFORMAT
> 		NAME GTiff
> 		DRIVER "GDAL/GTiff"
> 		MIMETYPE "image/tiff"
> 		IMAGEMODE RGB
> 		EXTENSION "tif"
> 	END
> 	# Start of LAYER DEFINITIONS ---------------------------------------------
> 	# Layer: Nutzungs-Grenzen
> 	LAYER
> 		NAME "nutzungs-grenzen"
> 		#GROUP "nutzungs-grenzen"
> 		METADATA
> 			'OWS_TITLE' 'Nutzungs-Grenzen'
> 			"WFS_TITLE" "Nutzungs-Grenzen"
> 			"GML_INCLUDE_ITEMS"  "all"
> 			"GML_FEATUREID"      "ID"
> 		END
> 		MAXFEATURES 1000
> 		EXTENT  -70000 180000 -1000 280000	#for EPSG:31254
> 		DATA "/data/Geodaten/Grenzen/DKM/Vorarlberg/Nutzung/NFL"
> 		OPACITY  100
> 		TYPE polygon
> 		MINSCALEDENOM 100
> 		MAXSCALEDENOM 5001
> 		STATUS ON
> 		DUMP TRUE
> 		CLASS
> 			NAME "Nutzungs-Grenzen"
> 			STYLE
> 				WIDTH 0.25
> 				ANTIALIAS false
> 				OUTLINECOLOR 0 130 0
> 				BACKGROUNDCOLOR 0 130 0
> 			END #end style
> 		END
> 		PROCESSING "CLOSE_CONNECTION=DEFER"
> 	END #end layer
> END #end map
More information about the MapServer-users mailing list
