[mapserver-users] WFS with several SRS?
Rahkonen Jukka
Jukka.Rahkonen at mmmtike.fi
Tue Nov 8 13:51:14 EST 2011
I am not sure. It is allowed to use vendor parameters in WFS 1.0.0 and therefore so why not also srsName? Geoserver and TinyOWS both support the use of srsName with WFS 1.0.0 and for users it can sometimes be very useful. You can have a try with OpenGEO demo server which is at http://demo.opengeo.org/geoserver/wfs?service=wfs&version=1.0.0&request=getcapabilities.
For TinyOWS I you can compare the default
http://188.64.1.61/cgi-bin/tinyows?service=wfs&version=1.0.0&request=GetFeature&typename=lv:mml_railway
and with srsName as vendor parameter
http://188.64.1.61/cgi-bin/tinyows?service=wfs&version=1.0.0&request=GetFeature&typename=lv:mml_railway&srsName=EPSG:2393
With http POST the situation is probably different. srsName does not belong to WFS xml schema and therefore TinyOWS which is validating requests strictly does not accept srsName in WFS 1.0.0 POST requests. However, I am remembering that Geoserver and probably also deegree WFS both accept srsName also in WFS 1.0.0 GetFeature with POST method.
I have been thinking that what is a real improvement in WFS 1.1.0 for majority of users is the support for srsName and what seems to be useful in WFS 2.0.0 is support for paging (use maxFeatures and offset for gathering WFS data in chunks). It would have been nice to add those two features into WFS 1.0.0 and let versions 1.1.0 and 2.0 for those who really love troubles.
-Jukka Rahkonen-
-Jukka Rahkonen-
________________________________________
Lähettäjä: mapserver-users-bounces at lists.osgeo.org [mapserver-users-bounces at lists.osgeo.org] käyttäjän Yewondwossen ASSEFA [yassefa at dmsolutions.ca] puolesta
Lähetetty: 8. marraskuuta 2011 15:39
Vastaanottaja: sulu
Kopio: mapserver-users at lists.osgeo.org
Aihe: Re: [mapserver-users] WFS with several SRS?
Multiple SRS is only valid for wfs 1.1 and higher.
The support of it in MapServer was added only for MapServer 6.0 [1].
Hope this helps.
[1] http://trac.osgeo.org/mapserver/ticket/3227
best regards,
Y. Assefa
On 11-11-08 05:37 AM, sulu wrote:
> I would like to offer a WFS-Service which supports several different
> projections.
> ("WFS_SRS" "EPSG:31254 EPSG:3785 EPSG:4326 EPSG:31284 EPSG:32632
> EPSG:25832 EPSG:21781")
> My mapserver is of version 5.6.6 on a Centos-Box
> MapServer version 5.6.6 OUTPUT=GIF OUTPUT=PNG OUTPUT=JPEG OUTPUT=WBMP
> OUTPUT=SVG SUPPORTS=PROJ SUPPORTS=AGG SUPPORTS=FREETYPE SUPPORTS=ICONV
> SUPPORTS=WMS_SERVER SUPPORTS=WMS_CLIENT SUPPORTS=WFS_SERVER
> SUPPORTS=WFS_CLIENT SUPPORTS=FASTCGI INPUT=EPPL7 INPUT=POSTGIS INPUT=OGR
> INPUT=GDAL INPUT=SHAPEFILE
> As expected the default SRS is 31254.
> A GetFeature-Call with this EPSG works just fine:
> Example:
> http://vogis.cnv.at/cgi-bin/mapserv?map=wfs.map&SERVICE=WFS&VERSION=1.1.0&REQUEST=GetFeature&TYPENAME=nutzungs-grenzen&SRSNAME=epsg:31254
> But if i try a other SRS from the WFS_SRS (e.g. 4326) above i receive:
> msWFSGetFeature(): WFS server error. Invalid GetFeature Request: SRSNAME
> value should be valid for all the TYPENAMES. Please check the capabilities
> and reformulate your request.
> As you can see in the Mapfile below, i avoided specifying any projection in
> the layer section so i have to wonder what i am doing wrong?
> Thanks
> Andy
> MAPFILE
> MAP
> EXTENT -70000 180000 5000 280000 #for EPSG:31254
> FONTSET ./fontset
> IMAGETYPE png
> MAXSIZE 8000
> RESOLUTION 96
> SYMBOLSET ./etc/symbol/symbols.sym
> # Debugging
> CONFIG "MS_ERRORFILE" "/tmp/mapserver_wfs_error.txt"
> DEBUG 5
> WEB
> METADATA
> "WFS_TITLE" "DKM Vorarlberg"
> EPSG:32632 EPSG:25832 EPSG:21781"
> "WFS_ABSTRACT" "Geodaten des Bundeslandes Vorarlberg als OGC-WFS"
> "WMS_SRS" "EPSG:4326 EPSG:31254 EPSG:31284 EPSG:32632
> "WMS_TITLE" "DKM Vorarlberg"
> "WMS_ABSTRACT" "Geodaten des Bundeslandes Vorarlberg als OGC-WMS"
> #"WMS_ONLINERESOURCE"
> "http://vogis.cnv.at/mapserver/mapserv?map=wfs.map&version=1.1.0"
> "WMS_FORMATLIST" "image/gif,image/png,image/jpeg,image/tif"
> "WMS_FEATURE_INFO_MIME_TYPE" "text/html"
> END
> END
> OUTPUTFORMAT
> NAME jpg
> DRIVER "GDAL/JPEG"
> MIMETYPE "image/jpeg"
> IMAGEMODE RGB
> EXTENSION "jpg"
> END
> OUTPUTFORMAT
> NAME jpg
> DRIVER "GDAL/JPEG"
> MIMETYPE "image/jpg"
> IMAGEMODE RGB
> EXTENSION "jpg"
> END
> OUTPUTFORMAT
> NAME gif
> DRIVER "GD/GIF"
> MIMETYPE "image/gif"
> IMAGEMODE PC256
> EXTENSION "gif"
> END
> OUTPUTFORMAT
> NAME png
> # Driver AGG/PNG weil der GDAL-Driver Probleme bei der Transparenz hat
> DRIVER "AGG/PNG"
> MIMETYPE "image/png"
> IMAGEMODE RGBA
> EXTENSION "png"
> TRANSPARENT ON
> FORMATOPTION "INTERLACE=OFF"
> END
> OUTPUTFORMAT
> NAME wbmp
> DRIVER "GD/WBMP"
> MIMETYPE "image/wbmp"
> IMAGEMODE PC256
> EXTENSION "wbmp"
> END
> OUTPUTFORMAT
> NAME GTiff
> DRIVER "GDAL/GTiff"
> MIMETYPE "image/tiff"
> IMAGEMODE RGB
> EXTENSION "tif"
> END
> # Start of LAYER DEFINITIONS ---------------------------------------------
> # Layer: Nutzungs-Grenzen
> LAYER
> NAME "nutzungs-grenzen"
> #GROUP "nutzungs-grenzen"
> METADATA
> 'OWS_TITLE' 'Nutzungs-Grenzen'
> "WFS_TITLE" "Nutzungs-Grenzen"
> "GML_INCLUDE_ITEMS" "all"
> "GML_FEATUREID" "ID"
> END
> MAXFEATURES 1000
> EXTENT -70000 180000 -1000 280000 #for EPSG:31254
> DATA "/data/Geodaten/Grenzen/DKM/Vorarlberg/Nutzung/NFL"
> OPACITY 100
> TYPE polygon
> MINSCALEDENOM 100
> MAXSCALEDENOM 5001
> STATUS ON
> DUMP TRUE
> CLASS
> NAME "Nutzungs-Grenzen"
> STYLE
> WIDTH 0.25
> ANTIALIAS false
> OUTLINECOLOR 0 130 0
> BACKGROUNDCOLOR 0 130 0
> END #end style
> END
> PROCESSING "CLOSE_CONNECTION=DEFER"
> END #end layer
> END #end map
> View this message in context: http://osgeo-org.1803224.n2.nabble.com/WFS-with-several-SRS-tp6973831p6973831.html
> Sent from the Mapserver - User mailing list archive at Nabble.com.
Assefa Yewondwossen
Software Analyst
Email: assefa at dmsolutions.ca
http://www.dmsolutions.ca/
Phone: (613) 565-5056 (ext 14)
Fax: (613) 565-0925
