[mapserver-users] Two Layers not matching up when one is
reprojected
Stephen Woodbridge
woodbri at swoodbridge.com
Thu Nov 10 00:10:24 EST 2011
I use the following definition:
<900913> +proj=merc +a=6378137 +b=6378137 +lat_ts=0.0 +lon_0=0.0
+x_0=0.0 +y_0=0 +k=1.0 +units=m +over +nadgrids=@null +no_defs <>
and have never gad a problem. Give it a try.
-Steve W
On 11/9/2011 11:06 PM, Matthew Pettis wrote:
> Hi,
> I am reprojecting a layer of Minnesota county boundaries from epsg:26915
> to be commensurate with a google maps overlay (epsg:3857 aka
> epsg:900913). The county overlay is shifted down from the Google Maps
> map by I'm guessing to be about 10 miles. Relevant links to map with
> Openlayers, straight mapserver map of counties, and the contents of the
> mapfile for the counties are below.
> My question is: Do I have a data problem, or is it a mapserver
> reprojection problem? Or is it a proj4 reprojection problem?
> In addition, I am including the epsg codes and the proj.4 equivalents I
> got from spatialreference.org <http://spatialreference.org> and stuck
> into my proj/epsg file:
> # got proj/epsg entries from proj4 link at:
> http://spatialreference.org/ref/sr-org/6864/ :
> <3785> +proj=merc +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=6378137 +b=6378137
> +towgs84=0,0,0,0,0,0,0 +units=m +no_defs <>
> <3857> +proj=merc +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=6378137 +b=6378137
> <900913> +proj=merc +lon_0=0 +k=1 +x_0=0 +y_0=0 +a=6378137 +b=6378137
> Help is much appreciated,
> Thanks,
> Matt
> Map Overlays: http://209.20.85.148/scratch/google-state.htm
> Straight mapserver output of county overlay:
> http://209.20.85.148/cgi-bin/mapserv?mode=map&map=/var/www/scratch/county-epsg900913.map
> <http://209.20.85.148/cgi-bin/mapserv?mode=map&map=/var/www/scratch/county-epsg900913.map>
> County Map (epsg:26916) mapfile (county-epsg900913.map):
> MAP
> # Map attributes
> IMAGETYPE PNG
> # epsg:3785 http://spatialreference.org/ref/epsg/3785/proj4/
> # Convert
> EXTENT -10779406.34 5378456.81 -9951631.67 6334157.39
> PROJECTION
> "init=epsg:3857"
> END
> SIZE 700 700
> IMAGECOLOR 244 244 244
> FONTSET "/home/matt/votevis/mapserver-files/fonts/fonts.list"
> # Layers
> # Counties
> # Renders different thickness borders at different scales
> LAYER
> NAME "county"
> DATA "/home/matt/votevis/MN/2010-election/shp/shp_counties"
> STATUS default
> TYPE polygon
> PROJECTION
> "init=epsg:26915"
> END
> CLASS
> NAME "county_lg"
> STYLE
> OUTLINECOLOR 111 111 111
> COLOR -1 -1 -1
> WIDTH 3
> END
> END
> END # Layer county
> END # MAP
> Do not seek to follow in the footsteps of the wise men of old. Seek what
> they sought.
> - Matsuo Munefusa (”Basho”)
> mapserver-users at lists.osgeo.org
