[mapserver-users] GetFeatureInfo: Search returned no results,
with OGR-DATA
Uwe Raudszus
URaudszus at STADTDO.DE
Tue Nov 15 05:24:28 EST 2011
Hello All,
I'm trying to migrate to MapServer 6.0.1. Now I have a Problem with
GetFeatureInfo Request to OGR-Datasets.
I have stored the same Data in to GIS-Formats (MapInfo tab an ESRI Shp). The
Layer Definition in my mapfile is:
LAYER # Stadtbezirksgrenzen
# Name und Geometrietyp
NAME "Stadtbezirksgrenzen"
TYPE POLYGON
# Sichtbarkeit
STATUS OFF
MINSCALE 0
MAXSCALE 25000000
#DEBUG TRUE
# Datenquelle
DATA "statist/shp/Stadtb_region.shp"
#CONNECTIONTYPE OGR
#CONNECTION "statist/Stadtb.TAB"
PROJECTION
"init=EPSG:31466"
#"init=EPSG:25832"
END
# Darstellung in der Karte.
# Stadtbezirk
CLASS
STYLE # Umrandung
OUTLINECOLOR 255 0 0
SYMBOL "Linie"
Size 2
END
END
# für HTML queries
TEMPLATE "./html/objektinfo.html"
METADATA # Für OGC Services
"WMS_ENABLE_REQUEST" "*"
"WMS_SRS" "EPSG:31466 EPSG:31467 EPSG:25832 EPSG:44122 EPSG:35832
EPSG:4326"
"WMS_TITLE" "Stadtbezirksgrenzen"
"WMS_abstract" "Stadtbezirksgrenzen der Stadt Dortmund"
"WMS_keywordlist" "Stadtbezirk"
"WMS_opaque" "0"
"GML_INCLUDE_ITEMS" "all"
"WMS_INCLUDE_ITEMS" "all"
"WMS_FEATURE_INFO_MIME_TYPE" "text/html"
"WMS_ENCODING" "ISO-8859-1"
END
END
If I use the Shapefile as Datasource the FeatureInfo Request works fine:
Request:
http://asgeow02.stadtdo.de/mapserver6/mapserver?map=/GDI_Programme/UMNMapServer6/Dienste/Geobasisdaten/wmstest.map&SERVICE=WMS&VERSION=1.3.0&REQUEST=GetFeatureInfo&BBOX=383996.973679,5706704.707753,396276.247858,5713754.308091&CRS=EPSG:25832&WIDTH=1175&HEIGHT=675&LAYERS=Stadtbezirksgrenzen&STYLES=&FORMAT=image/png&TRANSPARENT=TRUE&QUERY_LAYERS=Stadtbezirksgrenzen&INFO_FORMAT=text/plain&X=423&Y=83
Response:
GetFeatureInfo results:
Layer 'Stadtbezirksgrenzen'
Feature 11:
STBEZNR = '9'
EDATUM = '19891231'
GELösCHT = ''
FORTFühRUN = '19941001'
BEZEICHNUN = 'MENGEDE'
If I use the MapInfo (OGR) as Datasource, i get no result.
Layer Definition change:
#DATA "statist/shp/Stadtb_region.shp"
CONNECTIONTYPE OGR
The Request is the same.
Response:
Search returned no results.
The getMap-Request works fine with both Datasources.
Thanks for any help!
Uwe
View this message in context: http://osgeo-org.1803224.n2.nabble.com/GetFeatureInfo-Search-returned-no-results-with-OGR-DATA-tp6995758p6995758.html
Sent from the Mapserver - User mailing list archive at Nabble.com.
