[mapserver-users] Problem with Variable Substitution for
EXPRESSION
Lime, Steve D (DNR)
Steve.Lime at state.mn.us
Tue Nov 15 10:07:12 EST 2011
See http://www.regular-expressions.info/floatingpoint.html for some good examples.
Steve
From: mapserver-users-bounces at lists.osgeo.org [mailto:mapserver-users-bounces at lists.osgeo.org] On Behalf Of Prabu Raja
Sent: Tuesday, November 15, 2011 4:29 AM
To: mapserver-users at lists.osgeo.org
Subject: [mapserver-users] Problem with Variable Substitution for EXPRESSION
I need to compare one attribute from database table in "EXPRESSION" (under "LAYER") with six different values passed as Variable Substitution for coloring the layer.
I did added validation for those variables in the map file, but for some reason I am getting the below error.
msValidateParameter(): Regular expression error. Parameter pattern validation failed.
msEvalRegex(): Regular expression error. String failed expression test.
Could anyone help me with where I am wrong? Below is the map file content for this layer.
All the six variables would be numbers (may be a decimal number), Is my regular expression correct?
WEB
VALIDATION
value_one "^[\d+(\.\d)]*$"
value_two "^[\d+(\.\d)]*$"
value_three "[^\d+(\.\d)]*$"
value_four "[^\d+(\.\d)]*$"
value_five "[^\d+(\.\d)]*$"
value_six "[^\d+(\.\d)]*$"
END
END
LAYER
NAME "state"
TYPE polygon
STATUS ON
CONNECTIONTYPE POSTGIS
CONNECTION "user=postgres password=****** dbname=shpdb host=localhost port=5432"
DATA "the_geom FROM (SELECT gid, the_geom, totpop1 FROM state_shape) AS SUBQUERY using unique gid"
PROCESSING "CLOSE_CONNECTION=DEFER"
CLASSITEM "totpop1"
OPACITY 100
CLASS
EXPRESSION ([TOTPOP1] >= %value_one% AND [TOTPOP1] < %value_two%)
STYLE
COLOR 255 108 118
OUTLINECOLOR 255 255 255
END
END
CLASS
EXPRESSION ([TOTPOP1] >= %value_two% AND [TOTPOP1] < %value_three%)
STYLE
COLOR 254 189 75
END
END
CLASS
EXPRESSION ([TOTPOP1] >= %value_three% AND [TOTPOP1] < %value_four%)
STYLE
COLOR 254 247 46
END
END
CLASS
EXPRESSION ([TOTPOP1] >= %value_four% AND [TOTPOP1] < %value_five%)
STYLE
COLOR 39 251 114
END
END
CLASS
EXPRESSION ([TOTPOP1] >= %value_five% AND [TOTPOP1] <= %value_six%)
STYLE
COLOR 108 111 205
END
END
END
Regards,
Prabu Raja
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20111115/c2470466/attachment-0001.html
