[mapserver-users] style level opacity issue
thomas bonfort
thomas.bonfort at gmail.com
Thu Nov 17 14:16:45 EST 2011
I've just run a quick check and opacity on the style object works
correctly. please come up with a self contained test case that
reproduces your issue.
regards,
thomas
On Thu, Nov 17, 2011 at 18:15, Huotari, John B (RCIS)
<John.Huotari at rcis.com> wrote:
> I’d likewise like to see an answer to this as I’ve thus far been unable to
> make opacity work at the style level. I’ve worked around that by using the
> opacity at the layer level instead, which might be a suitable solution in
> your situation.
> From: mapserver-users-bounces at lists.osgeo.org
> [mailto:mapserver-users-bounces at lists.osgeo.org] On Behalf Of
> lists at killface.org
> Sent: Thursday, November 17, 2011 10:02 AM
> To: mapserver-users at lists.osgeo.org
> Subject: [mapserver-users] style level opacity issue
> I'm trying to render a single vector layer that has overlapping polygons,
> but I cant seem to get the settings correct for what I want. There are
> overlapping polygons on the layer, and I would like them to each be drawn
> transparently so that I can see the overlapping regions. However, no matter
> what I try I can't seem to get this effect and the rendering will make the
> shapes draw over each other.
> I'm using Mapserver 6.0.1
> OUTPUTFORMAT
> NAME "png"
> DRIVER AGG/PNG
> MIMETYPE "image/pngt"
> IMAGEMODE RGBA
> EXTENSION "png"
> FORMATOPTION "GAMMA=1.0"
> TRANSPARENT TRUE
> END
> I have a very simple class for my layer
> CLASS
> STYLE
> OPACITY 25
> COLOR [color]
> OUTLINECOLOR -1 -1 -1
> ANTIALIAS TRUE
> END
> LABEL
> COLOR 0 0 255
> OUTLINECOLOR 250 250 250
> OUTLINEWIDTH 3
> FONT stMYFont
> TYPE truetype
> SIZE 9
> POSITION AUTO
> PARTIALS FALSE
> MINFEATURESIZE AUTO
> END
> END
